    Grove Step Counter BMA456 - Never Triggers Interrupt - Steps Never Accumulate
    Jar444
    I am using the Bosch API that I modified to work with the nRF52832 and the Grove Step Counter Grove - Step Counter(BMA456) | Seeed Studio Wiki
    I am attempting to see the step counter output or if the interrupt triggers but it seems it doesn't as when reading either register they are always 0.
    I would love to hear any ideas of how to modify my code or even if you think perhaps the Grove step counter may be to blame. Thank you for any help.
    Here is the output on Putty:
    This is the code I am currently working on:
     * Copyright (c) 2022 Bosch Sensortec GmbH. All rights reserved.
     * SPDX-License-Identifier: BSD-3-Clause
    #include <stdio.h>
    #include "bma456h.h"
    #include "common.h"
    #include <zephyr/drivers/uart.h>
    /*!            Function                                                       */
    /* This function starts the execution of program. */
    int main(void)
        /* Variable to store the status of API */
        int8_t rslt;
        int8_t enable_rslt;
        /* Sensor initialization configuration */
        struct bma4_dev bma = { 0 };
        /* Variable to store step counter interrupt status */
        uint16_t int_status = 0;
        /* Variable to store step counter output */
        uint32_t step_out = 0;
        /* Variable to store activity status */
        uint8_t activity_output = 0;
        /* Interface reference is given as a parameter
         *         For I2C : BMA4_I2C_INTF
         *         For SPI : BMA4_SPI_INTF
         * Variant information given as parameter - BMA45X_VARIANT
        printf("\nStart new step counter example\n");
        rslt = bma4_interface_init(&bma, BMA4_I2C_INTF, BMA45X_VARIANT);
        bma4_error_codes_print_result("bma4_interface_init", rslt);
        printf("bma4_interface_init status %d\n", rslt);
        /* Sensor initialization */
        rslt = bma456h_init(&bma);
        bma4_error_codes_print_result("bma456h_init status", rslt);
        printf("bma456h_init status %d\n", rslt);
        /* Upload the configuration file to enable the features of the sensor. */
        rslt = bma456h_write_config_file(&bma);
        bma4_error_codes_print_result("bma456h_write_config status", rslt);
        printf("bma456h_write_config status %d\n", rslt);
        /* Enable the accelerometer */
        rslt = bma4_set_accel_enable(BMA4_ENABLE, &bma);
        bma4_error_codes_print_result("bma4_set_accel_enable status", rslt);
        printf("bma4_set_accel_enable status %d\n", rslt);
        // rslt = bma4_get_accel_enable(&enable_rslt, &bma);
        // bma4_error_codes_print_result("bma4_get_accel_enable status", rslt);
        // printf("bma4_get_accel_enable status %d\n", enable_rslt);
        // rslt = bma456h_feature_enable(BMA456H_STEP_COUNTER_EN, BMA4_ENABLE, &bma);
        // bma4_error_codes_print_result("bma456h_feature_enable status: step counter enabled", rslt);
        // printf("bma456h_feature_enable status: step counter enabled %d\n", rslt);
        if (rslt == BMA4_OK)
            /* Map the interrupt pin 1 for step counter */
            rslt = bma456h_map_interrupt(BMA4_INTR1_MAP, BMA456H_ACTIVITY_INT, BMA4_ENABLE, &bma);
            bma4_error_codes_print_result("bma456h_map_interrupt status", rslt);
            printf("bma456h_map_interrupt status %d\n", rslt);
            rslt = bma456h_map_interrupt(BMA4_INTR2_MAP, BMA456H_STEP_CNTR_INT, BMA4_ENABLE, &bma);
            rslt = bma456h_map_interrupt(BMA4_INTR1_MAP, BMA456H_STEP_CNTR_INT, BMA4_ENABLE, &bma);
                /* By setting watermark level 1, the output step resolution is 20 steps.
                * By setting watermark level 0, it provides output for each step for step detection.
                rslt = bma456h_step_counter_set_watermark(1, &bma);
                bma4_error_codes_print_result("bma456h_step_counter_set_watermark status", rslt);
                printf("set watermark status %d\n", rslt);
                    /* Enabling step counter feature */
                    // rslt = bma456h_feature_enable(BMA456H_STEP_DETECTOR_EN, BMA4_ENABLE, &bma);
                    // bma4_error_codes_print_result("bma456h_feature_enable status: step detector enabled", rslt);
                    // printf("bma456h_feature_enable status: step detector enabled %d\n", rslt);
                    // rslt = bma456h_feature_enable(BMA456H_STEP_ACTIVITY_EN, BMA4_ENABLE, &bma);
                    // bma4_error_codes_print_result("bma456h_feature_enable status: step activity enabled", rslt);
                    // printf("bma456h_feature_enable status: step activity enabled %d\n", rslt);
                printf("Step counter feature is enabled\n");
                printf("Step counter watermark level is 1 (Output resolution is 20 steps)\n");
                printf("Move the board in steps to perform step counter\n");
                for (;;)
                    /* Read the interrupt status (After 20 steps, generates interrupt) */
                    rslt = bma456h_read_int_status(&int_status, &bma);
                    bma4_error_codes_print_result("bma456h_read_int_status", rslt);
                    if (int_status != 0){
                        printf("bma456h_read_int_status status %d\n", int_status);
                    /* Enters only if the obtained interrupt is step counter */
                    if ((rslt == BMA4_OK) && (int_status & BMA456H_STEP_CNTR_INT))
                        //printf("Step counter interrupt received when watermark level is reached (20 steps)\n");
                        rslt = bma456h_step_counter_output(&step_out, &bma);
                        bma4_error_codes_print_result("bma456_step_counter_output status", rslt);
                        if (step_out != 0){
                            printf("The step counter output is %lu\n", (long unsigned int)step_out);
                int_status = 0;
        return rslt;
    4 REPLIES 4
    Hi Jar444,
    You can refer attached exmaple code on STM32, enable macro definition in user_define.h
    #define USE_BMA456H
    #elif defined(USE_BMA456H)
    #define STEP_COUNTER_WATERMARK
    Thank you for the prompt response. Are you suggesting I need a user_define.h that enables macro definitions? I am using the nRF52832. May I please get more clarity on this fix? Thank you very much for your help.
    I have switch to the BMA456w code as I am trying to impliment the step tracker for a wearable. The big issue is the interrupt status register never triggers the interrupt for the step tracker. When I use the dubugger and check the registers inreal time they never change values. The step counter stays zero. This BMA456 works when I use an arduino and the code from seeed.  The step tracker does start counting up. Thank you so very much for any help.
    Hi Jar444,
    There are different versions(BMA456W, BMA456H, BMA456MM, BMA456AN) of BMA456 sensor API on Github, so I used macro definitions to distinguish them. You only need to care about the macro definition and code corresponding to the step counter.
    The reference code runs on an embedded platform using C language, and you can port it to nRF52832 and see the running results.
