    HS code
    HS code
    This is a non technical question but maybe someone can help.
    We are importing PCB board with BME280 from China to Europe. I am looking for the righ HS code. HS code is Harmonized System code and is used by customs to make the importer pay the right custom taxes.
    I am hesitating between different values:
    8542 39 11 or 8542 31 00 or 9025 80 40 50
    Anyone did it already?
    The exact product we are importing is this one: https://fr.aliexpress.com/item/4001219561707.html
    Re: HS code
    The HS code for BME280 is 8542 39 00.
    Re: HS code
    Thanks for your answer.
    8542 39 00 does not seem to exist, so closest should be 8542 39 11. (See https://www.tariffnumber.com/2020/854239)
    In the meantime, I also got an answer from Bosch customer support and here is their answer.
    Dear valued customer,
    thank you very much for your inquiry and your interest in our products.
    The tariff number for the BME280 is 90258080. However, if it is only the sensor for third-party components, we cannot make any recommendations.
    Best regards,
    Re: HS code
    Thanks for the information.
    The HS code of 8542 39 00 is from year 2017. If the code of 90258080 works for you, then you should be good.
