06-21-2022 04:38 PM
I am looking for a Arduino compatible 1mbar accuracy pressure sensor (BMP180 or 280 actually) to measure Helium pressure.
I did not find information about the capacity of BMP180 or BMP280 to measure Helium pressure, neither on this forum nor or on the internet. Does someone know anything about that ?
Thanks a lot in advance for your help !
06-22-2022 04:40 AM
Hi Jamily,
As long as the pressure range you want to measure does not exceed the range of BMP280, you can use it to measure.
The accuracy in BMP280 data sheet for your reference.
06-22-2022 04:20 PM
Duly noted, thanks a lot for your help !
