    How can I check BMI160's accuracy?
    yasu_999
    Hi.
    If I want to check the accuracy of angular velocity and acceleration measurements, which part of the datasheet should I look at?
    Is it  the same as the description of max or min sensitivity (or resolution)?
    And, I would also like to know the accuracy of angular velocity and acceleration when repeated measurements are taken after offset.
    I know this is a rudimentary question, but I'd like to know.
    Tags (1)
    Re: How can I check BMI160's accuracy?
    Hello yasu_999,
    You could refer the chapter "1.2 ELECTRICAL AND PHYSICAL CHARACTERISTICS, MEASUREMENT PERFORMANCE" in BMI160 data sheet.
    yasu_999
    Hello BSTRobin,
    Thanks for your reply.
    I read the datasheet and understood the following, is it correct?
    Without considering external disturbance, the accuracy of 1 bit of measurement at 25 degC and 16G range is determined by the reciprocal of sensitivity, 1/2130~1/1966.
    And, the temperature and overvoltage supply will cause changes in the accuracy of the measurement.
    Hello yasu_999,
    You could refer the table "output signal accelerometer" and "output signal gyroscope".
