    How can I select the right Accelerometer?
    Highlighted
    I am designing a sensor to measure vibration from industrial equipment.
    The main required characteristics of the accelerometer are listed below:
    - Acceleration Range - up to 8g
    - Type - Digital
    - Output Type - I²C, SPI
    - Axis - X / Y / Z
    - Bandwidth - minimum of 1.6KHz (as higher the better)
    - Resolution - 16 bits
    I found a lot of accelerometer that meet the specifications above, although I am not being able to understand how can I guarantee a good resolution in high frequencies of the accelerometer.
    I already tested the MPU9250 in a shaker and the results in low frequency (until 150Hz) is reasonable, although in high frequencies (from 150Hz until 1kHz) it is horrible as shown below:
    ps- the blue dots are the reference accelerometer (piezoeletric) and the orange dot is the MPU9250.
    My question is:
    • How can I understand from the datasheet that the resolution in high frequency will be ok?
    Highlighted
    Re: How can I select the right Accelerometer?
    The component of choice would be BMA456.
    However, note that the maximum data rate is 1600Hz, and the maximum filter bandwidth is 684Hz (3dB cutoff frequency).
    o_o
