    How can I verify the trimming coefficients of the BMP390 sensor?
    agai
    Occasional Visitor
    How can I verifiy the trimming coefficients stored in the NVM of the BMP390 sensor? I would expect to find a checksum somewhere in the NVM section and a corresponding checksum formula in order to be able to verify the values. This is a memory dump of the trimming coefficients received from the BMP390 (Register addresses: 0x31 - 0x45):
    trimming coefficients bmp390trimming coefficients bmp390
    Re: How can I verify the trimming coefficients of the BMP390 sensor?
    BMP390 doesn't have checksum to verify if the read from NVM for the coefficient parameters are correct or not. Basically you could run self-test at https://www.bosch-sensortec.com/media/boschsensortec/downloads/application_notes_1/bst-mps-an006.pdf. If the self-test passes, then it means the parameters from NVM are correct. Otherwise, the self-test will fail.
    BMP390 API source code can be found at https://github.com/BoschSensortec/BMP3-Sensor-API.
