    How can i recompile stuffelf utilitty
    amoniev
    How can i recompile stuffelf utility in BHI260_SDK
    7 REPLIES 7
    Minhwan
    Hello amoniev,
    the stuffelf utility does not output Trigger Lists means that no stuffelf.exe in release folder?
    I don't understand your issue.
    Let me clear BHI260 SDK and please elaborate in your situation.
    1) stuffelf.exe in BHI260_SDK\win64\bin once you install
    2) When you release software, stuffelf.exe copy to release folder if there is no error. If there is some error in your application, you have to fix first.
    Where your issue happens?
    Thanks for the help. The question was resolved. It is necessary to remove the -q switch when starting stuffelf in the BHI260_SDK \ common \ 7189 \ USER_RAM \ config.cmake file. Then the Trigger Lists is output to the terminal.
    Minhwan
    Good to hear that 🙂
