    How do i set a specific configuration?
    itsmaxdd
    In the bsec_iot_init function, is this uint8_t bsec_config[BSEC_MAX_PROPERTY_BLOB_SIZE] = {"generic_33v_3s_4d"}; enough  ?
    2 REPLIES 2
    itsmaxdd
    Actually i think
    bsec_config_len = config_load(bsec_config_iaq, sizeof(bsec_config_iaq));
    if (bsec_config_len != 0) {
         ret.bsec_status = bsec_set_configuration(bsec_config_iaq, bsec_config_len, work_buffer, sizeof(work_buffer));
         if (ret.bsec_status != BSEC_OK)
         return ret;
    Actually this, with  bsec_config_iaq from the *.c file, right?
    handytech
    If you successfully add the bsec_serialized_configurations_iaq.c/.h files to your compilation dependencies, your code snippet will indeed use the bsec_config_iaq array from the C file.
