Hi, i want to readout the data of my BME280 environment sensor but somehow i don't get any results. I only found, that you have to connect CSB to VDDIO, for I2C to be active and pulled SDO to GND.
What else do i have to do?
Thanks for your support! 🙂
Hello nicoheggli,
For BME280 I2C hardware connection, you could refer the following diagram froom BME280 datasheet.
For BME280 SW driver, you could refer github link. https://github.com/BoschSensortec/BME280_driver
Thanks, I've already made the hardware connections but I still have trouble with initializing the sensor. Which values have to be set for the sensor to be initialized?
Hello nicoheggli,
You could use the driver code and example code in github.
