    How to Convert BMI160 Data into roll, pitch and yaw
    amar
    Hi everyone,
    Present i am working with BMX160, Till i am able to read Three sensor's raw data(Acc, Gyro, Mag) and convert them into Gravity, Radiuns/sec,uT respectively and To converting these readings iinto roll, pitch, yaw i am using below section of code(i got this from google)like below.
    #define   ACCELEROMETER_SENSITIVITY       16384.0
    #define  GYROSCOPE_SENSITIVITY                  16.4 //from bmx160 datasheet pg no:9,it is the value form range FS2000
    #define   M_PI        3.14159265359
    #define   dt        0.01   // 10 ms sample rate!
    void ComplementaryFilter(int16_t *accData, int16_t *gyrData, float *pitch, float *roll)
    float pitchAcc, rollAcc, yaw = 0.0;
    float *yaw_ptr;
    // Integrate the gyroscope data -> int(angularSpeed) = angle
    *pitch = ( (float)gyro.x / GYROSCOPE_SENSITIVITY ) * dt; // Angle around the X-axis
    *roll = ( (float)gyro.y / GYROSCOPE_SENSITIVITY ) * dt; // Angle around the Y-axis
    yaw = yaw + ((float)gyro.z) * dt; // Angle around the Z-axis
    yaw_ptr = &yaw;
    // Compensate for drift with accelerometer data if !bull**bleep**
    // Sensitivity = -2 to 2 G at 16Bit -> 2G = 32768 && 0.5G = 8192
    int forceMagnitudeApprox = abs(accel.x) + abs(accel.y) + abs(accel.z);
    if (forceMagnitudeApprox > 8192 && forceMagnitudeApprox < 32768)
    // Turning around the X axis results in a vector on the Y-axis
    pitchAcc = atan2f((float)accel.y, (float)accel.z) * 180 / M_PI;
    *pitch = *pitch * 0.98 + pitchAcc * 0.02;
    // Turning around the Y axis results in a vector on the X-axis
    rollAcc = atan2f((float)accel.x, (float)accel.z) * 180 / M_PI;
    *roll = *roll * 0.98 + rollAcc * 0.02;
    PRINTF("pitch\t%0.5f\troll\t%0.5f\tyaw\t%0.5f\t\r\n", *pitch,*roll, yaw);
    Can you please review it once.
    If it is wrong to proceede so please correct me and suggeat me right  formula for converting it.
    Thank you inadvance,
    amarr
    Yanchao
    We have formula as bellow:
    #define GRAVITY_EARTH   (9.80665f) /* Earth's gravity in m/s^2 */
    #define RAD             (57.2957805f)
    #define INV_RAD         (0.01745329f)
     *  @brief This internal API is used to convert lsb to ms2
     *  @param[in] val: value
     *  @param[in] range: range value
     *  @param[in] bit_width
     *  @return float value in ms2
    float lsb_to_ms2(int16_t val, float g_range, uint8_t bit_width)
    	float half_scale = (float)(1 << bit_width) / 2.0f;
    	return GRAVITY_EARTH * val * g_range / half_scale;
    float lsb_to_mg(int16_t val, float g_range, uint8_t bit_width)
    	return 1000.0f * val * g_range / half_scale;
    float lsb_to_dps(int16_t val, float g_range, uint8_t bit_width)
    	return val * g_range / half_scale;
    example:
    accel_x = lsb_to_ms2(accel_data[i].x, 8, 16);
    gyro_x = lsb_to_dps(gyro_data[i].x, 2000, 16);
    #define MAG_FRAMES	20
    struct bmm150_mag_data mag_data[MAG_FRAMES];
    rslt = bmm150_aux_mag_data(aux_data[i].data, &bmm150dev);
    mag_data[i].x = bmm150dev.data.x;
    mag_data[i].y = bmm150dev.data.y;
    mag_data[i].z = bmm150dev.data.z;
