    How to analyze the data of BMI270
    Eason
    Hallo everyone
    I have obtained the originaldata from BMI270, but  these data are not processed. How to convert these data into data with standard units. For example: m/s^2  (accelerometer) and rad/s (gyroscope).
    Thank you very much.
    Accel_xAccel_yAccel_zGyr_xGyr_yGyr_z
    19-42616660141
    10-42116646141
    2-43816671231
    205-5801667503-22
    -81888917469131-537-128
    2022-59116579333-93778
    3457151117143961-97177
    2104444715315849173-113
    -1136224156043838805
    -1441498015571-2761401-454
    -3889420614484-785900-792
    -600177216052-1714-758-587
    -3700-40216576-1230-909-234
    -3414-373817029-896-1380127
    1718-284216151836-904189
    2032787185601090-179217
    Hello Eason,
    There were example code in github.
    For accelerometer,  you could example file "https://github.com/BoschSensortec/BMI270-Sensor-API/blob/master/examples/bmi270/accel/accel.c".
    * @brief This function converts lsb to meter per second squared for 16 bit accelerometer at
    * range 2G, 4G, 8G or 16G.
    static float lsb_to_mps2(int16_t val, float g_range, uint8_t bit_width)
    float half_scale = ((float)(1 << bit_width) / 2.0f);
    return (GRAVITY_EARTH * val * g_range) / half_scale;
    For gyroscope, you could example file "https://github.com/BoschSensortec/BMI270-Sensor-API/blob/master/examples/bmi270/gyro/gyro.c".
    * @brief This function converts lsb to degree per second for 16 bit gyro at
    * range 125, 250, 500, 1000 or 2000dps.
    static float lsb_to_dps(int16_t val, float dps, uint8_t bit_width)
    return (dps / ((half_scale) + BMI2_GYR_RANGE_2000)) * (val);
