    How to configure acceleration range of Nicla Sense ME (BHI260AP)?
    chinoramas
    I have a nicla sense ME IMU sensor and I want to evaluate the various sensitivity range of the accelerometer?
    Does anyone have an idea how to change the acceleration range parameter in Arduino?
    Or any sample code that I can refer to?
    I tried to search and found something but still, I cannot get it how to implement it on the program.
    Thank you
    Regards
    Christian
    10 REPLIES 10
    zgg
    Long-established Member
    Hi
    This has actually already been implemented, you could refer to the:
    https://github.com/arduino/nicla-sense-me-fw/blob/main/Arduino_BHY2/src/BoschSensortec.cpp
    BoschSensortec::configureSensorRange() invokes the API: bhy2_set_virt_sensor_range() to change the dynamic range.
    you could refer to the datasheet  section 13.2.8  for more details such as the units of the range.
    Let me know if this helps and / or if you have additonal questions.
    void BoschSensortec::getSensorConfiguration(uint8_t id, SensorConfig& virt_sensor_conf)
    gets the configuration (incl. the dynamic range) of the sensor.
    Where do I put this command into? Ignore my stupidity, I'm pretty new to this stuff, trying to do a school project.
    zgg
    Hi Jbarton
    no worries.
    you could try this, e.g.:
    in the example sketch: https://github.com/arduino/nicla-sense-me-fw/blob/main/Arduino_BHY2/examples/Standalone/Standalone.i...
    you could add a line,
    void setup()
    Serial.begin(115200);
    while(!Serial);
    BHY2.begin();
    accel.begin();
    accel.setRange(16);  // this is an example, you might need to change this to 4, 8 or 16 based on your needs
    gyro.begin();
    temp.begin();
    gas.begin();
    rotation.begin();
    zgg
    BTW, there is a new PR on the github which adds a new example on how to read and reconfigure the range of the IMU on Nicla Sense.
    Please check the details here:
    https://github.com/arduino/nicla-sense-me-fw/pull/65/commits/9c6858f55613c9ee8944aba8e47c8a79a63ba5b...
    you could find a new sketch which does exactly that.
    Thank you for your  solution. Is there any way to set range from Host side? for example, i read nicla sensor data from portenta h7 by BHY2_Host libra, but there isn't any function to set range
