    How to detect crash using BMI 323?
    gunbu99
    hello
    I'm trying to detect crash using bmi 323.
    I used anymotion feature but it doesn't work as I thought
    I think when crash occurs, imu's accelerometer may be 4g.
    therefore I set registers below
    // use feature engine
    FEATURE_IO2 = 0x012C
    FEATURE_IO_STATUS = 0x0001
    FEATURE_CONTROL = 0x0001
    // normal mode on
    ACCL_CONF = 0x42a8 //acc_mode = normal mode, bw : odr/4, acc_range : 8g, acc_odr :100Hz
    GYRO_CONF = 0x0000
    // any motion setting
    EXT_ANYMO_1 = 0x1800 // acc_thres : 4g
    FEATURE_IO0 = 0x0038 // any motion x,y,z int enable
    // interrupt
    INT_MAP1 = 0x0004 // interrupt mapping, any motion out: INT1
    IO_INT_CTRL = 0x0005 // INT1 active high, push-pull, enable
    GEN_SET_1 = 0x0011 // event report mode enable, interrupt hold time duration : 40ms
    it doesn't work. there's no interrupt while I swing board with imu
    if acc_thres is under 10/512g, interrupt happen
    I don't understand why this works like that
    plz help me. I want to detect crash using  bmi 323
    6 REPLIES 6
    FAE_CA1
    In your code you did not configure BMI323 accel slope (any-motion) interrupt threshold. Please refer to Github example at https://github.com/boschsensortec/BMI323_SensorAPI/blob/main/examples/any_motion/any_motion.c for more information.
    sorry but I don't get it
    in EXT.ANYMO_1 register, I set slope_thres as 4g and in INT_MAP1 register, I set anymotion out
    plz refer me what register you said.
    thanks
    FAE_CA1
    Yes, you did set the threshold to 4g, I did not see it. Sorry.
    Let me try your settings on BMI323 shuttle board to see if any-motion interrupt works or not. I will get back to you later.
    As I said, interrupt happens when I set slope_thres as 10/512g in EXT.ANYMO_1.
    I just don't understand why bmi323 is working like that.
    I think that if slope_thres is 10/512g, interrupt happens even though it shake a very little. but in actual situation, interrupt happens when I swing it very hardly.
    plz answer and explain how anymotion works.
    that's the point I don't understand.
