Hi community,
Since BSXLite library does not support BMI088, I wonder how to do temperature compensation and calibration without the lib.
Is the temperature compensation function nees to be implemented by the user or it is integrated in the chip? And what is the procedures?
Best regards.
There is temperature sensor inside BMI088 on the accel part.
From host MCU, you can put sensor into temperature chamber, read out the raw data and temperature value in certain temperature point.
Then draw a line to match sensor performance with temperature changes.
Through this way, you are able to get the temperature effect be compensated with calculated transfer function in lab.
Since you get directly support from local FAE, you can also go for detail instruction about how to do it.
