    How to get full range on BMI323
    dev_gnrb
    I'm using a BMI323 Shuttle Board 3.0 Flyer connected in I²C on an Arduino Uno R3 thanks to a level shifter.
    My problem is when I read X, Y or Z axis, the return value sould be between -32768 and 32768 (2^16). But my usable range is -16384-> 16384, the other part (-32768 to -1616384 and 16385 to 32768) is never returned, why ?
    It seems it's working on 15 bits instead of 16 bits, do you know why is it working like that ?
    I'll link my Arduino code.
    My accelerometer is setup as follow:
    * ODR: 0x000C -> 1600Hz
    * range: 0x0000 -> 2G
    * filtering: 0x0000 -> ODR/2
    * average: 0x0600 -> 64 sample
    * mode: 0x7000 -> High
    So I send 0x760C to the ACC_CONF register.
    Thanks !
    Re: How to get full range on BMI323
    Hi dev_gnrb,
    If you set BMI323 acc range to 2G, raw data output range should be -16384~+16384.
    dev_gnrb
    But 16384*2 = 32768 so it's not 16 bits right ? 🤔
    Hi dev_gnrb,
    The sign bit uses 1 bit, and the output data contains positive and negative.
