    How to interface BME680 with PIC32MK1024GPK064 controller?
    ankur
    I need to interface BME680 with PIC32MK1024GPK064 but I didn't find the library file for the same.
    Below are the software details:
    MCU detailed type: PIC32MK1024GPK064 and PIC32MK Curiosity Pro Development Board
    IDE version: MPLAB X IDE v5.40
    Compiling options: XC32 v2.41
    Kindly suggest how can I integrate BME680 with the PIC32MK1024GPK064 controller.
    Thank you,
    Ankur Patel
    23 REPLIES 23
    Hello Minhwan,
    Thanks for the BSEC library.
    What is the range for the "breath_voc_equivalent"  and "co2_equivalent" parameter?
    regards,
    Ankur Patel
    Minhwan
    Hello Ankur,
    Regarding eCO2 and bVOC, please check table 5 and 18 in BME680 datasheet.
    Hello Minhwan,
    As per you suggestion I looked at the tables :
    - In table 18 (from datasheet) I didn't found about related to B-VOC/eCO2.
    - In table 5 (from datasheet), mentions the "B-VOC mixture with Nitrogen as carrier gas".
           - I have not found the minimum and maximum limits of B-VOC.
    Regards,
    Ankur Patel
    Minhwan
    Hello Ankur,
    Here is the details,
    • bVOCeq estimate: (Range 0.5 - 1000 ppm)
      • The breath VOC equivalent output (bVOCeq) estimates the total VOC concentration [ppm] in the environment. It is calculated based on the sIAQ output and derived from lab tests.
    • CO2eq estimate: (Range 400-... ppm)
      • Estimates a CO2-equivalent (CO2eq) concentration [ppm] in the environment. It is also calculated based on the sIAQ output and derived from VOC measurements and correlation from field studies
