09-30-2020 08:42 AM
Hello Community! We have recently purchased an Application Board and somehow we need a mechanism to start the logging with the Development Desktop 2.0 through command prompt. Is there a CLI or API such that takes a configuration file as an input and starts logging using the IMU inside the Application Board? Until now, I have always recorded all the data available (acceleration, gyro, temperature, magnetic field, etc. ) to get an idea about the shock and vibration.
Thank you very much for the help!
Best regards,
Rozerin.
09-30-2020 10:40 PM
You can save data log using DD 2.0 UI interface.
However, if you want to save some data using API, you should read some data from sensor register.
Please check GenericAPI UserManual.pdf below path.
C:\Program Files\Bosch Sensortec\Development Desktop 2.0\UserpApplicationBoard\GenericAPI UserManual.pdf
