    How to read trim values of Magnetometer of BMX160
    cwi
    As far as I've understood the trim values need to be read from the BMX160 via the mag_if registers.
    Following the datasheet:
    For a read access:
    Write magnetometer register address to read from into Register (0x4D) MAG_IF[1]
    Read
    Register (0x1B) STATUS
    until the bit mag_man_op is “0”
    Read Register (0x04-0x0B) DATA_0 to DATA_7, get the data from magnetometer
    1. First setting the Powermode: 0x19 -> BMX160_COMMAND_REG_ADDR
    2. Set setup mode with burst read 8 bytes: 0x83 -> BMX160_MAG_IF_0_ADDR
    3. Write Regaddres too MAG_IF1: BMM150_DIG_Z4_LSB -> BMX160_MAG_IF_1_ADDR
    wait 10 ms
    4. Read Status byte and check bit man_mag_op is "0"
    5. Read Register (0x04-0x0B) DATA_0 to DATA_7, get the data from magnetometer
    But I am always getting zeros and not data.
    Help is apreciated.
    Best regrads,
    Constantin
    Jet
    Occasional Contributor
    Re: How to read trim values of Magnetometer of BMX160
    Hi Sir:
         I think first you should check PMU_STATUS(0X03)  to know mag_if_pmu_status.
         BMX160 is regared BMI160 and BMM150 integration.
         There is only a different CHIP_ID between BMX160 and BMI160+BMM150.
         If want to get mag data, you need to open BMI160 aux interface and BMM150 POWER_CNTRL_ENABLE.
         Ragarding operating BMM150 which is in BMX160 as a Magnetometer, you can reference the follow link:
