03-23-2021 07:25 AM
We have a system buit with BME680 sensor on it. We have integrated BSEC into software.
To test in the lab after entire system is ready, to get the IAQ level what things we can do in our lab to achieve that rather than going somewhere?
03-23-2021 08:23 AM
Hello Sridhar,
After you integrated BSEC SW in your system, have you got IAQ output value?
03-23-2021 12:44 PM
After I integrated the code I have read IAQ only once as 25. AFter that system hangs maybe related to porting issue.
So even in the initial time to change IAQ please tell how to do that in lab.
03-24-2021 04:12 AM
Hello Sridhar,
First of all, you need to be able to get the data normally without system hang up. Then you do the test.
03-24-2021 08:06 AM
We will try to fix that anyway. What we need to know is, any kind of instruments to buy to inject some type of gas in order to verify BME680 gas IAQ value is coming correctly or not.
