    How to use BSEC_IOT exemple for the BME680
    hamady
    Hello
    I'm using the BME680 in STMCubeIDE with a STM32WLE,
    I succed in importing all the files for the bsec algo with the 'bme680_iaq_33v_300s_4d' settings.
    And i used the GCC cortex M4 libalgobsec.a file
    I want the library to be called by my own sleep callback function that will be triggered every 120 sec (or semething close to BSEC requirement), to read IAQ data.
    So i used the files in 'BSEC_Integration_Examples'
    void sleep_n(uint32_t t_us, void *intf_ptr)
    	//HAL_LPTIM_Counter_Start_IT(&hlptim1,(32768/ 128) * t_us);     //20sec timer
    	//Delay_us(t_us);
    int64_t get_timestamp_us()
    	int64_t system_current_time = 0;
    	// Please insert system specific function to retrieve a timestamp (in microseconds)
    	system_current_time =((int64_t)(HAL_GetTick())*1000);
    	return system_current_time;
    uint32_t state_load(uint8_t *state_buffer, uint32_t n_buffer)
        // Load a previous library state from non-volatile memory, if available.
        // Return zero if loading was unsuccessful or no state was available,
        // otherwise return length of loaded state string.
        return 0;
     * @brief           Save library state to non-volatile memory
     * @param[in]       state_buffer    buffer holding the state to be stored
     * @param[in]       length          length of the state string to be stored
     * @return          none
    void state_save(const uint8_t *state_buffer, uint32_t length)
        // Save the string some form of non-volatile memory, if possible.
    	//SPI_Flash_Erase_4K(SECTOR_STATE_BSEC);
    	//SPI_Flash_Write_Bytes(SECTOR_STATE_BSEC,length+1,state_buffer);
    	//SPI_Flash_Sleep();
    uint32_t config_load(uint8_t *config_buffer, uint32_t n_buffer)
        /*memcpy(config_buffer, Selectivity_config, n_buffer);
        return n_buffer;*/
    	return 0;
    void output_ready(int64_t timestamp, float gas_estimate_1, float gas_estimate_2, float gas_estimate_3, float gas_estimate_4,
         float raw_pressure, float raw_temp, float raw_humidity, float raw_gas, uint8_t raw_gas_index, bsec_library_return_t bsec_status)
        int64_t timestamp_int = (int64_t)timestamp;
        int32_t gas_estimate_1_int = (int32_t)gas_estimate_1;
        int32_t gas_estimate_2_int = (int32_t)gas_estimate_2;
        int32_t gas_estimate_3_int = (int32_t)gas_estimate_3;
        int32_t gas_estimate_4_int = (int32_t)gas_estimate_4;
        int32_t raw_pressure_int = (int32_t)raw_pressure;
        int32_t raw_temp_int = (int32_t)raw_temp;
        int32_t raw_humidity_int = (int32_t)raw_humidity;
        int32_t raw_gas_int = (int32_t)raw_gas;
        int32_t raw_gas_index_int = (int32_t)raw_gas_index;
        int32_t bsec_status_int = (int32_t)bsec_status;
        APP_LOG(TS_ON, VLEVEL_L, "Timestamp: %lld, Gas Estimate 1: %d, Gas Estimate 2: %d, Gas Estimate 3: %d, Gas Estimate 4: %d, Raw Pressure: %d, Raw Temperature: %d, Raw Humidity: %d, Raw Gas: %d, Raw Gas Index: %d, BSEC Status: %d\r\n",
                timestamp_int, gas_estimate_1_int, gas_estimate_2_int, gas_estimate_3_int, gas_estimate_4_int, raw_pressure_int, raw_temp_int, raw_humidity_int, raw_gas_int, raw_gas_index_int, bsec_status_int);
    	Enable_sensor_BME680();
    	return_values_init ret;
    	struct bme68x_dev bme_dev;
    	memset(&bme_dev,0,sizeof(bme_dev));
    	bme_dev.intf = BME68X_SPI_INTF;
    	bme_dev.read = bme68x_spi_read;
    	bme_dev.write = bme68x_spi_write;
    	bme_dev.delay_us = bme68x_delay_us;
    	//bme_dev.intf_ptr = &communicationSetup;
    	bme_dev.amb_temp = 25;
    	ret = bsec_iot_init(BSEC_SAMPLE_RATE_ULP, 0.0f, bme68x_spi_write, bme68x_spi_read, sleep_n, state_load, config_load, bme_dev);
    	if (ret.bme68x_status)
    			/* Could not initialize BME68x */
    			APP_LOG(TS_ON, VLEVEL_L,"Error while initializing BME68x: %d",ret.bme68x_status);
    			return;
    		else if (ret.bsec_status)
    			/* Could not initialize BSEC library */
    			APP_LOG(TS_ON, VLEVEL_L,"Error while initializing BSEC library: %d",ret.bsec_status);
    			return;
    Here i can see that the BME680 is initalised but when the code come to the bsec init the MCU stop working.
    Also what is the code to be called when i trigger my sleep callback function (LPTIM)
    9 REPLIES 9
    hamady
    To add more information i added these file in the BSEC2.4.0.0_Generic_Release_23012023 :
    C:\Users\Hamady\Desktop\BSEC2.4.0.0_Generic_Release_23012023\algo\normal_version\bin\gcc\Cortex_M4
    C:\Users\Hamady\Desktop\BSEC2.4.0.0_Generic_Release_23012023\algo\normal_version\inc
    C:\Users\Hamady\Desktop\BSEC2.4.0.0_Generic_Release_23012023\config\bme680\bme680_iaq_33v_300s_4d
    C:\Users\Hamady\Desktop\BSEC2.4.0.0_Generic_Release_23012023\examples\BSEC_Integration_Examples\src\inc
    C:\Users\Hamady\Desktop\BSEC2.4.0.0_Generic_Release_23012023\examples\BSEC_Integration_Examples\src\config
    C:\Users\Hamady\Desktop\BSEC2.4.0.0_Generic_Release_23012023\examples\BSEC_Integration_Examples\examples\bsec_iot_example
    Here my main that give me a error -12 in updating the subscription in BSEC_SAMPLE_RATE_ULP but not in BSEC_SAMPLE_RATE_SCAN (all on the integration function like sleep,timestamp ect.. are good)
    	bsec_iot_init(BSEC_SAMPLE_RATE_ULP, 0.0f, bme68x_spi_write, bme68x_spi_read, sleep, state_load, config_load, bme_dev);
    And also how to modify the bsec_iot_loop() to have a utilisation when my MCU sleep for 300s, wake up, read BME680 data, read BSEC IAQ and goes to sleep.
    hamady
    Any idea how to fix this issue ?
    Hi hamady,
    First, we need to know if you need IAQ or gas identification through BSEC? The default code is an example of running gas identification, as described in the subscription function bme68x_bsec_update_subscription().
    hamady
    I only need IAQ from BSEC,
