    How to use Build Flags for proper BME6xx Library Use
    lgacnik97
    I'm using Nucleo-F756ZG board from STM vendor. I'm using VS Code with PlatformIO extension. Here, I can provide various compiler/assembler/linker options which are considered during build and link process. I'm not sure how I should implement these flags because, as far as I know, its only instructed how to do this on Arduino platform. This are the instructions I'm referring to:
    # Algorithm inclusion
     * The static library path needs to be included in the platform.txt file.
     * In the platforms.txt search ‘recipe.c.combine.pattern’ and adding where your library is located after ‘{object_files}’, just like this:
       recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" "-Wl,--Map={build.path}/{build.project_name}.map" "-L{compiler.sdk.path}/lib" "-L{compiler.sdk.path}/ld" "-L{compiler.sdk.path}/{build.memory_type}" {compiler.c.elf.flags} {compiler.c.elf.extra_flags} {build.extra_flags} -Wl,--start-group {object_files} "C:\Users\Name\Documents\Projects\Bsec_Library\libalgobsec.a" "{archive_file_path}" {build.extra_libs} {compiler.c.elf.libs} {compiler.libraries.ldflags} -Wl,--end-group -Wl,-EL -o "{build.path}/{build.project_name}.elf"
     * Configurations can be copied to files Selectivity_Config.c & Selectivity_Config.h which is included by default
     * Note to not change the variable name as they are already linked in the repositrory.
    I'm able to link against "libalgobsec.a" static library however I get more errors, which refer to inidividual output files within this library. So, translating these options to my platform might solve this issues I'm facing.
    Hi lgacnik97,
    Could we know detailed information about your compiler information?
    If your compiler is gcc, you can link libalgobsec.a under folder "BSEC2.4.0.0_Generic_Release_23012023\algo\normal_version\bin\gcc\Cortex_M7".
