10-12-2021 03:16 PM
Hallo zusammen,
When I export an algorithm from BME AI-Studio, I get four files:
The "file.config" enables me to implement the algorithm using the Development Kit and the Development Kit App on my Android phone.
My question is: how can I implement the algorithm in my C++ or C code to run it on my microcontroller?
My goal is to be able to use my algorithm to detect classes, similar to when I use the BSEC library to detect the air quality?
Danke im Voraus
10-12-2021 08:35 PM
Hello Meh,
AI studio exported files can be used with BSEC 2.
Once you download bsec 2, there is config folder and there are many config files.
BSEC 2 use config files as c and h files, so please put your custom config file in your folder and include it in your application.
02-06-2022 02:27 PM
Can you please explain what do you mean by "put your custom config file in your folder and include it in your application". I have generated config file and then I unzipped the BSEC2 library and paste my config file into this library's config folder and then I zipped that library file again and tried to import that zipped file as BSEC2 library into arduiono. But arduino says invalid library. Can you please explain how can I use the config file generated form AI studio in Arduino for further applications?
Thankyou
Shehzad
