    How would a BNO055 react in space ?
    MatCn
    I know that the Datasheet mentions that the BNO055 is intended to be use in typical gravity and magnetic field of earth and not in space application but what if? How would it react?
    • Would it work with a lower gravity, especially the fusion algorithm NDOF? For instance, 0g for the ISS, 0.16g for the Moon and 0.38g for Mars.
    • How fast would it adapt to a change of gravity?
    • What would be the lowest magnetic field at which the sensor could work?
    • How fast are the fusion algorithms (typically NDOF) adapting to a change of magnetic field?
    Does any of you has an idea about these questions?
    Thank you in advance,
    Best regards
    Jet
    Occasional Contributor
    Re: How would a BNO055 react in space ?
    Hi Sir:
     Your question is very professional, because BST sensors are only the consumer electrical products and are only used in Earth, we haven't had some experimentation to verify these scenarios.
    If you want to use them in some special condition, recommend you to verify them by yourself.
