I am attempting to just output every step for testing so I can see the interface working. I have used the API from Bosch and have gotten the config file loaded sucessfully. I have enabled the step counter but when I read the register it is always 0. Any suggestions? Thank you in advance for any help.
* Copyright (c) 2022 Bosch Sensortec GmbH. All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include <stdio.h>
#include "bma456h.h"
#include "common.h"
/*! Function */
/* This function starts the execution of program. */
int main(void)
/* Variable to store the status of API */
int8_t rslt;
/* Sensor initialization configuration */
struct bma4_dev bma = { 0 };
/* Variable to store step counter interrupt status */
uint16_t int_status = 0;
/* Variable to store step counter output */
uint32_t step_out = 0;
/* Interface reference is given as a parameter
* For I2C : BMA4_I2C_INTF
* For SPI : BMA4_SPI_INTF
* Variant information given as parameter - BMA45X_VARIANT
printf("\nStart new step counter example\n");
rslt = bma4_interface_init(&bma, BMA4_I2C_INTF, BMA45X_VARIANT);
bma4_error_codes_print_result("bma4_interface_init", rslt);
printf("bma4_interface_init status %d\n", rslt);
/* Sensor initialization */
rslt = bma456h_init(&bma);
bma4_error_codes_print_result("bma456h_init status", rslt);
printf("bma456h_init status %d\n", rslt);
/* Upload the configuration file to enable the features of the sensor. */
rslt = bma456h_write_config_file(&bma);
bma4_error_codes_print_result("bma456h_write_config status", rslt);
printf("bma456h_write_config status %d\n", rslt);
/* Enable the accelerometer */
rslt = bma4_set_accel_enable(BMA4_ENABLE, &bma);
bma4_error_codes_print_result("bma4_set_accel_enable status", rslt);
printf("bma4_set_accel_enable status %d\n", rslt);
if (rslt == BMA4_OK)
/* Map the interrupt pin 1 for step counter */
rslt = bma456h_map_interrupt(BMA4_INTR1_MAP, BMA456H_STEP_CNTR_INT, BMA4_ENABLE, &bma);
bma4_error_codes_print_result("bma456h_map_interrupt status", rslt);
printf("bma456h_map_interrupt status %d\n", rslt);
/* Setting watermark level 1, the output step resolution is 20 steps.
* Eg: 1 means, 1 * 20 = 20. Every 20 steps once output triggers
// rslt = bma456h_step_counter_set_watermark(0, &bma);
// bma4_error_codes_print_result("bma456h_step_counter_set_watermark status", rslt);
// printf("set watermark status %d\n", rslt);
/* Enabling step counter feature */
rslt = bma456h_feature_enable(BMA456H_STEP_COUNTER_EN, BMA4_ENABLE, &bma);
bma4_error_codes_print_result("bma456h_feature_enable status: step counter enabled", rslt);
printf("bma456h_feature_enable status %d\n", rslt);
rslt = bma456h_feature_enable(BMA456H_STEP_DETECTOR_EN, BMA4_ENABLE, &bma);
bma4_error_codes_print_result("bma456h_feature_enable status: step detector enabled", rslt);
printf("Step counter feature is enabled\n");
//printf("Step counter watermark level is 1 (Output resolution is 20 steps)\n");
printf("Move the board in steps to perform step counter\n");
for (;;)
/* Read interrupt status */
// rslt = bma456h_read_int_status(&int_status, &bma);
// bma4_error_codes_print_result("bma456h_read_int_status", rslt);
// //printf("bma456h_read_int_status status %d\n", rslt);
// /* Enters only if the obtained interrupt is step counter */
// if ((rslt == BMA4_OK) && (int_status & BMA456H_STEP_CNTR_INT))
//printf("Step counter interrupt received when watermark level is reached (20 steps)\n");
rslt = bma456h_step_counter_output(&step_out, &bma);
if (rslt == BMA4_OK && step_out > 0){
printf("The step counter output is %lu\n", (long unsigned int)step_out);
//break;
bma.delay_us(1000000, bma.intf_ptr);
//int_status = 0;
return rslt;
