05-26-2021 10:52 AM
Hi all,
I'm using the Arduino GitHub repository for use a BME680 sensor with the BSEC software. I'm making the code with VSCode and Platformio with a Zero Arduino board which have a Cortex M0+. Platformio compile the "libalgobsec.a" library without errors.
The application request a new data every 5 minutes with the "run()" method of the BSEC object. So the configuration have been made with the "generic_18V_300s_4d" file and "BSEC_SAMPLE_RATE_ULP".
When the program starts, the IAQ accuracy change from 0 to 1 in about 20 minutes but this value (1) remains for more than 15 hours with no change to 2 but sometimes changes to 0. The IAQ value changes between 25 and 250.
I tried made the application with 3 seconds sample option and the result is that it does change but the 3 IAQ accuracy value is continusly changes with accuracy 2.
I share my code in case there is something wrong. Attach the IAQ and IAQ accuracy data too. The time that you will see it's the time of the sent to a server but the "tick2()" function of the code is executed every 300 seconds with +-5 ms of error.
Appreciate any help.
Bsec iaqSensor;
String output;
uint8_t bsecState[BSEC_MAX_STATE_BLOB_SIZE] = {0};
uint16_t stateUpdateCounter = 0;
const uint8_t bsec_config_iaq[] = {
#include "config/generic_18v_300s_4d/bsec_iaq.txt"
void checkIaqSensorStatus(void) {
if (iaqSensor.status != BSEC_OK) {
if (iaqSensor.status < BSEC_OK) {
output = "BSEC error code : " + String(iaqSensor.status);
RH_UART_DEBUG.println(output);
_delay::s(1);
// for (;;) errLeds(); /* Halt in case of failure */
} else {
output = "BSEC warning code : " + String(iaqSensor.status);
if (iaqSensor.bme680Status != BME680_OK) {
if (iaqSensor.bme680Status < BME680_OK) {
output = "BME680 error code : " + String(iaqSensor.bme680Status);
_delay::s(1);
// for (;;) errLeds(); // Halt in case of failure
} else {
output = "BME680 warning code : " + String(iaqSensor.bme680Status);
_delay::s(1);
void loadState(void) {
if (EEPROM.read(0) == BSEC_MAX_STATE_BLOB_SIZE) {
// Existing state in EEPROM
Serial.println("Reading state from EEPROM");
for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE; i++) {
bsecState[i] = EEPROM.read(i + 1);
Serial.println(bsecState[i], HEX);
iaqSensor.setState(bsecState);
checkIaqSensorStatus();
} else {
// Erase the EEPROM with zeroes
Serial.println("Erasing EEPROM");
for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE + 1; i++)
EEPROM.write(i, 0);
EEPROM.commit();
void updateState(void) {
bool update = false;
/* Set a trigger to save the state. Here, the state is saved every
* STATE_SAVE_PERIOD with the first state being saved once the algorithm
* achieves full calibration, i.e. iaqAccuracy = 3 */
if (stateUpdateCounter == 0) {
if (iaqSensor.iaqAccuracy >= 3) {
update = true;
stateUpdateCounter++;
} else {
/* Update every STATE_SAVE_PERIOD milliseconds */
if ((stateUpdateCounter * STATE_SAVE_PERIOD) < millis()) {
update = true;
if (update) {
iaqSensor.getState(bsecState);
Serial.println("Writing state to EEPROM");
EEPROM.write(i + 1, bsecState[i]);
EEPROM.write(0, BSEC_MAX_STATE_BLOB_SIZE);
EEPROM.commit();
uint8_t tick2(uint8_t param) {
echo::info(F("ESTAMOS EN TICK2"));
unsigned long time_trigger = millis();
if (iaqSensor.run()) { // If new data is available
output = String(time_trigger);
output += ", " + String(iaqSensor.rawTemperature);
output += ", " + String(iaqSensor.pressure);
output += ", " + String(iaqSensor.rawHumidity);
output += ", " + String(iaqSensor.gasResistance);
output += ", " + String(iaqSensor.iaq);
output += ", " + String(iaqSensor.iaqAccuracy);
output += ", " + String(iaqSensor.temperature);
output += ", " + String(iaqSensor.humidity);
output += ", " + String(iaqSensor.staticIaq);
output += ", " + String(iaqSensor.co2Equivalent);
output += ", " + String(iaqSensor.breathVocEquivalent);
} else {
uint8_t err = puf::emit(EV_TICK1, 0);
if (err > 0) {
echo::error("Transmit error");
echo::info("Triying transmit again");
return 0;
void errLeds(void) {
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
digitalWrite(LED_BUILTIN, LOW);
delay(100);
uint8_t init(uint8_t param) {
char version[50];
// EEPROM.init(); // 1st address for the length
Wire.begin();
// Intialition BSEC object with I2C address. To select the other address:
// BME680_I2C_ADDR_SECONDARY
iaqSensor.begin(SENS_BME680_ADDRESS, Wire);
sprintf(version, "BSEC library version %u.%u.%u.%u", iaqSensor.version.major,
iaqSensor.version.minor, iaqSensor.version.major_bugfix,
iaqSensor.version.minor_bugfix);
Serial.println(version);
iaqSensor.setConfig(bsec_config_iaq);
loadState();
bsec_virtual_sensor_t sensorList[10] = {
BSEC_OUTPUT_RAW_TEMPERATURE,
BSEC_OUTPUT_RAW_PRESSURE,
BSEC_OUTPUT_RAW_HUMIDITY,
BSEC_OUTPUT_RAW_GAS,
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_STATIC_IAQ,
BSEC_OUTPUT_CO2_EQUIVALENT,
// Sets desired sensors and sample rate (more sample rates:
// bsec_datatypes.h)
iaqSensor.updateSubscription(sensorList, 10, BSEC_SAMPLE_RATE_ULP);
return 0;
OUTPUT
DATE IAQ IAQ Accuracy
26-05-21 08:44:09 132.98 1
26-05-21 08:39:14 122.24 1
26-05-21 08:34:09 117.59 1
26-05-21 08:29:09 143.09 1
26-05-21 08:24:09 140.65 1
26-05-21 08:19:09 125.13 1
26-05-21 08:14:09 132.42 1
26-05-21 08:09:09 117.78 1
26-05-21 08:04:11 109.59 1
26-05-21 07:59:09 134.84 1
26-05-21 07:54:09 139.30 1
26-05-21 07:49:09 140.31 1
26-05-21 07:44:10 135.23 1
26-05-21 07:39:11 146.98 1
26-05-21 07:34:09 143.59 1
26-05-21 07:29:10 153.56 1
26-05-21 07:24:22 161.00 1
26-05-21 07:14:20 194.04 1
26-05-21 07:09:10 157.41 1
26-05-21 07:04:15 123.45 1
26-05-21 06:59:10 130.16 1
26-05-21 06:54:10 112.98 1
26-05-21 06:49:13 104.60 1
26-05-21 06:44:10 123.72 1
26-05-21 06:39:10 198.72 1
26-05-21 06:34:10 250.00 1
26-05-21 06:29:10 116.85 1
26-05-21 06:24:12 58.17 1
26-05-21 06:19:10 25.00 1
26-05-21 06:14:10 27.24 1
26-05-21 06:09:10 25.00 1
26-05-21 06:04:11 41.72 1
26-05-21 05:59:11 31.74 1
26-05-21 05:54:11 36.14 1
26-05-21 05:49:11 25.00 1
26-05-21 05:44:11 25.00 1
26-05-21 05:39:12 31.13 1
26-05-21 05:29:12 26.79 1
26-05-21 05:24:11 35.00 1
26-05-21 05:19:11 31.57 1
26-05-21 05:14:11 40.31 1
26-05-21 05:09:11 34.98 1
26-05-21 05:04:12 42.42 1
26-05-21 04:59:11 32.36 1
26-05-21 04:54:12 28.37 1
26-05-21 04:49:12 32.42 1
26-05-21 04:44:12 36.08 1
26-05-21 04:39:12 43.79 1
26-05-21 04:34:16 44.10 1
26-05-21 04:29:12 47.42 1
26-05-21 04:24:12 44.60 0
26-05-21 04:19:16 44.30 0
26-05-21 04:14:12 40.25 0
26-05-21 04:09:12 35.63 0
26-05-21 04:04:11 35.63 1
26-05-21 03:59:17 35.63 1
26-05-21 03:54:12 32.11 1
26-05-21 03:49:12 35.29 1
26-05-21 03:44:13 33.24 1
26-05-21 03:39:13 31.95 1
26-05-21 03:34:13 32.72 1
26-05-21 03:29:13 36.49 1
26-05-21 03:24:13 28.15 1
26-05-21 03:19:13 25.00 1
26-05-21 03:14:13 31.66 1
26-05-21 03:09:13 34.12 1
26-05-21 03:04:18 32.28 1
26-05-21 02:59:13 25.00 1
26-05-21 02:54:13 32.15 1
26-05-21 02:49:14 30.64 1
26-05-21 02:44:14 28.42 1
26-05-21 02:39:14 31.26 1
26-05-21 02:34:14 34.94 1
26-05-21 02:29:14 34.26 1
26-05-21 02:24:14 26.35 1
26-05-21 02:19:14 34.41 1
26-05-21 02:14:14 25.00 1
26-05-21 02:09:14 25.00 1
26-05-21 02:04:15 25.00 1
26-05-21 01:59:14 25.00 1
26-05-21 01:54:14 35.23 1
26-05-21 01:39:14 37.73 0
26-05-21 01:29:14 31.31 0
26-05-21 01:24:14 26.30 0
26-05-21 01:19:12 26.30 1
26-05-21 01:14:18 26.30 1
26-05-21 01:09:14 27.23 1
26-05-21 01:04:14 27.49 1
26-05-21 00:59:14 35.74 1
26-05-21 00:54:14 39.14 1
26-05-21 00:49:15 39.07 0
26-05-21 00:44:14 37.07 0
26-05-21 00:39:14 33.94 0
26-05-21 00:34:14 28.27 0
26-05-21 00:29:12 28.27 1
26-05-21 00:24:14 28.27 1
26-05-21 00:19:14 29.39 1
26-05-21 00:14:14 28.47 1
26-05-21 00:09:14 41.25 1
26-05-21 00:04:15 36.47 1
25-05-21 23:59:14 38.69 1
25-05-21 23:54:15 45.62 1
25-05-21 23:49:15 42.16 1
25-05-21 23:39:15 25.00 1
25-05-21 23:34:15 32.23 1
25-05-21 23:29:15 30.52 1
25-05-21 23:24:15 34.94 1
25-05-21 23:19:15 25.33 1
25-05-21 23:14:15 32.41 1
25-05-21 23:09:15 33.12 1
25-05-21 23:04:15 29.70 1
25-05-21 22:59:15 42.86 1
25-05-21 22:54:15 37.36 1
25-05-21 22:49:16 30.35 1
25-05-21 22:44:15 32.19 1
25-05-21 22:39:15 36.44 1
25-05-21 22:34:15 36.63 1
25-05-21 22:29:15 33.75 1
25-05-21 22:24:15 25.00 1
25-05-21 22:19:15 28.77 1
25-05-21 22:14:15 29.84 1
25-05-21 22:09:15 25.00 1
25-05-21 22:04:16 27.60 1
25-05-21 21:59:16 27.63 1
25-05-21 21:54:16 38.21 1
25-05-21 21:49:16 25.27 1
25-05-21 21:44:16 28.15 1
25-05-21 21:39:16 27.38 1
25-05-21 21:34:16 34.76 1
25-05-21 21:29:16 25.00 1
25-05-21 21:24:16 30.44 1
25-05-21 21:19:16 25.00 1
25-05-21 21:14:16 29.70 1
25-05-21 21:09:16 25.00 1
25-05-21 21:04:16 25.00 1
25-05-21 20:59:16 25.86 1
25-05-21 20:54:16 31.16 1
25-05-21 20:49:16 31.88 1
25-05-21 20:44:16 28.02 1
25-05-21 20:39:16 33.85 1
25-05-21 20:34:16 33.81 1
25-05-21 20:29:16 30.25 1
25-05-21 20:24:16 39.24 1
25-05-21 20:19:16 36.08 1
25-05-21 20:14:16 37.51 1
25-05-21 20:09:16 35.12 1
25-05-21 20:04:16 35.00 1
25-05-21 19:59:16 38.24 1
25-05-21 19:54:17 25.00 1
25-05-21 19:49:17 30.88 1
25-05-21 19:44:17 25.00 1
25-05-21 19:39:17 31.32 1
25-05-21 19:34:17 30.47 1
25-05-21 19:29:17 28.03 1
25-05-21 19:24:17 42.23 1
25-05-21 19:19:17 43.23 1
25-05-21 19:14:17 34.38 1
25-05-21 19:09:17 25.00 1
25-05-21 19:04:17 25.58 1
25-05-21 18:59:17 33.94 1
25-05-21 18:54:17 39.03 1
25-05-21 18:49:17 48.12 1
25-05-21 18:44:17 46.22 1
25-05-21 18:39:17 41.82 1
25-05-21 18:34:17 45.60 1
25-05-21 18:29:17 59.27 1
25-05-21 18:24:17 48.42 1
25-05-21 18:19:17 48.02 1
25-05-21 18:14:17 52.64 1
25-05-21 18:09:17 57.17 1
25-05-21 18:04:17 66.58 1
25-05-21 17:59:17 58.61 1
25-05-21 17:54:17 54.61 1
25-05-21 17:49:17 60.27 1
25-05-21 17:44:18 62.77 1
25-05-21 17:39:18 61.92 1
25-05-21 17:34:18 61.45 1
25-05-21 17:29:18 62.07 1
25-05-21 17:24:18 57.92 1
25-05-21 17:19:18 70.62 1
25-05-21 17:14:18 74.72 1
25-05-21 17:09:18 63.66 1
25-05-21 17:04:18 62.11 1
25-05-21 16:59:18 59.77 1
25-05-21 16:54:18 46.66 1
25-05-21 16:49:18 61.05 1
25-05-21 16:44:18 75.51 1
25-05-21 16:39:18 55.58 1
25-05-21 16:34:18 81.29 1
25-05-21 16:29:18 83.64 1
25-05-21 16:24:18 81.89 1
25-05-21 16:19:18 79.78 1
25-05-21 16:14:19 79.15 1
25-05-21 16:09:19 115.93 1
25-05-21 16:04:19 86.37 1
25-05-21 15:59:19 64.15 1
25-05-21 15:54:19 87.72 1
25-05-21 15:49:19 63.15 1
25-05-21 15:44:19 39.39 1
25-05-21 15:39:19 36.35 1
25-05-21 15:34:19 43.48 1
25-05-21 15:29:19 25.00 1
25-05-21 15:24:19 38.36 1
25-05-21 15:19:19 25.00 1
25-05-21 15:14:19 25.00 1
25-05-21 15:09:19 25.00 0
25-05-21 15:04:19 25.00 0
25-05-21 14:59:19 25.00 0
25-05-21 14:54:20 25.00 0
25-05-21 14:49:18 25.00 0
25-05-21 14:44:20 25.00 0
05-27-2021 09:11 AM
Hello Danielms812,
If you use a new chip, it will take an hour to initialize the chip in ULP mode; It could be got the trusted IAQ value After 1 day.
It is recommended to test it with several devices.
From your timestamp log, it's not continuous. Can you check it?
05-31-2021 10:27 AM
Hello BSTRobin, thanks for the answer.
I'm using a CJMCU-680 module. I don't know if it's a new chip. Anyway, the sensor has been in operation for more than three days. Obviously, I can't post all data.
I've noticed that putting the sensor in a bad enviroment it only takes a few minutes for reach 2 IAQ accuracy value and then 3. But when the sensor is left back in the first environment after a while, it return to 2 and then 1 of accuracy and sometimes directly from 3 to 1. I supposed that it's a "trick" for achieve a trusted IAQ value in less time, but it isn't a good solution for me.
The timestamp log, as I said in the first post, it's the time the value have been sent to a server, but the BME680 "run()" function in the program, is called every 300 seconds with some miliseconds of error (10 maximum). I know it because I can see the timestamp in the serial monitor. In order to improve this, what is the maximum error that is permited ?
And what did you mean with "test with severeal devices". Several BME680 or several MCU. For this time, I only have one BME680.
The data I'll share you is a part of the last 4 days in which it can be seen the change from 3 to 1. Now almost 3 days later it still continues to present a 1 IAQ accuracy value.
What are you thinking is the problem ?
Daniel.
05-31-2021 10:46 AM
Change from 3 to 1.
29-05-21 01:12:40 1 33.65
29-05-21 01:07:39 1 27.30
29-05-21 01:02:38 1 25.00
29-05-21 00:57:37 1 32.12
29-05-21 00:52:36 1 35.52
29-05-21 00:47:35 1 29.86
29-05-21 00:42:34 1 34.70
29-05-21 00:37:33 1 32.14
29-05-21 00:32:32 1 25.00
29-05-21 00:27:32 1 25.00
29-05-21 00:22:31 1 31.14
29-05-21 00:17:30 1 28.90
29-05-21 00:12:29 1 31.91
29-05-21 00:07:28 1 27.77
29-05-21 00:02:27 1 38.33
28-05-21 23:57:26 1 36.84
28-05-21 23:52:25 1 25.00
28-05-21 23:47:24 1 25.00
28-05-21 23:42:23 1 31.76
28-05-21 23:37:22 1 35.06
28-05-21 23:32:21 1 25.65
28-05-21 23:27:20 1 25.00
28-05-21 23:22:19 1 25.00
28-05-21 23:17:18 1 25.00
28-05-21 23:12:18 1 34.97
28-05-21 23:07:17 1 28.63
28-05-21 23:02:16 1 30.65
28-05-21 22:57:15 1 27.40
28-05-21 22:52:14 1 31.90
28-05-21 22:47:13 1 31.93
28-05-21 22:42:12 1 32.88
28-05-21 22:37:11 1 36.58
28-05-21 22:32:10 1 35.37
28-05-21 22:27:09 1 41.40
28-05-21 22:22:08 1 35.30
28-05-21 22:17:07 1 34.70
28-05-21 22:12:06 1 36.88
28-05-21 22:07:05 1 38.08
28-05-21 22:02:04 1 42.39
28-05-21 21:57:03 1 41.37
28-05-21 21:52:02 1 43.67
28-05-21 21:47:02 1 45.11
28-05-21 21:42:01 1 43.49
28-05-21 21:37:00 1 46.24
28-05-21 21:31:59 1 53.63
28-05-21 21:26:58 1 46.33
28-05-21 21:21:57 1 48.53
28-05-21 21:16:56 1 45.66
28-05-21 21:11:55 3 49.40
28-05-21 21:06:54 3 45.84
28-05-21 21:01:53 3 49.81
28-05-21 20:56:52 3 51.18
28-05-21 20:51:51 3 50.64
28-05-21 20:46:50 3 49.17
28-05-21 20:41:49 3 47.96
28-05-21 20:36:49 3 52.12
28-05-21 20:31:48 3 53.70
28-05-21 20:26:47 3 53.68
28-05-21 20:21:46 3 45.43
28-05-21 20:16:45 3 44.14
28-05-21 20:11:44 3 49.75
28-05-21 20:06:43 3 47.44
28-05-21 20:01:42 3 58.91
28-05-21 19:56:41 3 60.31
28-05-21 19:51:40 3 57.87
28-05-21 19:46:39 3 56.89
28-05-21 19:41:38 3 62.99
28-05-21 19:36:37 3 54.79
28-05-21 19:31:37 3 57.46
28-05-21 19:26:36 3 56.22
28-05-21 19:21:35 3 57.26
28-05-21 19:16:34 3 63.37
28-05-21 19:11:33 3 65.17
28-05-21 19:06:32 3 65.87
28-05-21 19:01:31 3 65.46
28-05-21 18:56:30 3 62.74
28-05-21 18:51:29 3 63.39
28-05-21 18:46:28 3 65.72
28-05-21 18:41:27 3 67.93
28-05-21 18:36:26 3 60.22
28-05-21 18:31:25 3 70.48
28-05-21 18:26:24 3 77.66
28-05-21 18:21:24 3 75.87
28-05-21 18:16:23 3 80.97
28-05-21 18:11:22 3 72.79
28-05-21 18:06:21 3 88.90
Changing between 3 and 2 IAQ accuracy.
28-05-21 08:34:35 3 59.08
28-05-21 08:29:34 3 62.60
28-05-21 08:24:33 3 60.40
28-05-21 08:19:32 3 58.06
28-05-21 08:14:31 3 57.85
28-05-21 08:09:31 3 60.50
28-05-21 08:04:30 3 51.70
28-05-21 07:59:29 3 47.15
28-05-21 07:54:28 3 50.42
28-05-21 07:49:27 3 43.34
28-05-21 07:44:26 3 44.12
28-05-21 07:39:25 3 41.96
28-05-21 07:34:24 3 37.36
28-05-21 07:29:23 2 27.02
28-05-21 07:24:22 2 25.00
28-05-21 07:19:21 3 27.26
28-05-21 07:14:20 3 29.26
28-05-21 07:09:19 3 26.40
28-05-21 07:04:18 2 27.04
28-05-21 06:59:17 2 25.00
28-05-21 06:54:16 2 25.00
28-05-21 06:49:15 2 25.00
28-05-21 06:44:15 2 25.00
28-05-21 06:39:14 2 25.00
28-05-21 06:34:13 2 25.00
28-05-21 06:29:12 2 25.00
28-05-21 06:24:11 3 26.15
28-05-21 06:19:10 3 29.30
28-05-21 06:14:09 3 30.71
28-05-21 06:09:08 2 31.23
28-05-21 06:04:07 2 25.00
28-05-21 05:59:06 3 32.92
28-05-21 05:54:05 3 28.13
28-05-21 05:49:04 3 29.13
28-05-21 05:44:03 3 26.67
28-05-21 05:39:02 3 25.94
28-05-21 05:34:01 2 30.36
28-05-21 05:29:00 2 25.00
28-05-21 05:23:59 2 25.00
28-05-21 05:18:58 2 25.00
28-05-21 05:13:58 3 25.43
28-05-21 05:08:57 3 26.46
28-05-21 05:03:56 3 25.53
28-05-21 04:58:55 2 25.28
28-05-21 04:53:54 2 25.00
28-05-21 04:48:53 3 28.87
28-05-21 04:43:52 3 29.52
28-05-21 04:38:51 2 31.14
28-05-21 04:33:50 2 25.00
28-05-21 04:28:49 3 30.36
28-05-21 04:23:48 2 30.97
28-05-21 04:18:47 2 25.00
28-05-21 04:13:46 3 28.29
28-05-21 04:08:45 3 29.03
28-05-21 04:03:45 3 28.71
28-05-21 03:58:44 2 27.04
28-05-21 03:53:43 2 25.00
28-05-21 03:48:42 3 26.06
28-05-21 03:43:41 3 28.29
28-05-21 03:38:40 3 26.25
28-05-21 03:33:39 3 27.01
28-05-21 03:28:38 3 28.95
28-05-21 03:23:37 3 29.36
28-05-21 03:18:36 3 30.54
28-05-21 03:13:35 3 31.43
28-05-21 03:08:34 3 32.39
28-05-21 03:03:33 2 32.74
28-05-21 02:58:32 2 25.00
28-05-21 02:53:31 2 28.41
28-05-21 02:48:31 2 25.00
28-05-21 02:43:30 3 28.89
28-05-21 02:38:29 3 29.71
28-05-21 02:33:28 3 28.00
28-05-21 02:28:27 3 29.03
28-05-21 02:23:26 3 26.71
28-05-21 02:18:25 3 25.51
06-16-2021 09:19 AM
Hello Danielms812,
"test with several devices" means several sets of equipment, one set of equipment contains a MCU and bme680, and each set of software runs the same software, test at same time, same environment.
