    IAQ value not updating (BME688, BSEC2.0)
    MightyNate
    I'm trying to measure the IAQ with a BME688 sensor and the new BSEC2.0 library on an RaspberryPi.
    I had everything working with the BME680 and the BSEC1.4.
    All values despite the IAQ are calculated and updatet correctly but the IAQ status is 0 even after letting it run for over 20 minutes.
    What could be reasons for the IAQ to not update?
    Thanks for any advice
    Nathan
    Tags (3)
    9 REPLIES 9
    MightyNate
    Re: IAQ value not updating (BME688, BSEC2.0)
    I just let it run for over 1,5 hours and still no change.
    Hello MightyNate,
    Which power mode you configured?
    MightyNate
    I'm running the sensor in Low Power mode.
    MightyNate
    I just noticed, that the heat compensated temperature is constantly at around -4 degC which is very unrealistic.
    The raw temeperature is at around 29 degC which matches the weather prediction for my location.
    Might this be a hint  for what is going wrong?
    Besides I'm not using a statefile for the moment and I checked the timestamps, they seem plausible.
    Still the iaq accuracy is always at 0 even after hours of running in Low Power Forced Mode
