    Interfacing BME680 to STM32F769IDiscovery
    VinayakMH
    Dear BOSCH Community,
    I am working on interfacing BME680 sensor to STM32F769-IDiscovery microcontroller board.
    I got the following output. (May be garbage / raw values). Kindly help me in getting the correct values. And i have posted my stm code also. Kindly go thought that and help me in getting the right values.
    GAS RESISTANCE :1965753.865000
    TEMPERATURE : -48
    PRESSURE : 134225243
    HUMIDITY: -338783365
    This is my code:
    #include <stdio.h>
    #include "main.h"
    #include "retarget.h"
    #include "bme680.h"
    #include "bme680_defs.h"
    #include "math.h"
    struct bme680_dev gas_sensor;
    int8_t rslt = BME680_OK;
    I2C_HandleTypeDef hi2c1;
    UART_HandleTypeDef huart1;
    /* Private function prototypes -----------------------------------------------*/
    void SystemClock_Config(void);
    static void MX_GPIO_Init(void);
    static void MX_I2C1_Init(void);
    static void MX_USART1_UART_Init(void);
    int8_t user_i2c_read (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len)
    HAL_StatusTypeDef err;
    int result = 0;
    uint8_t reg[1]={reg_addr};
    err = HAL_I2C_Master_Transmit(&hi2c1, dev_id, reg, 1,HAL_MAX_DELAY);
    HAL_Delay(10);
    result = HAL_I2C_Master_Receive(&hi2c1, dev_id, data, len, HAL_MAX_DELAY);
    HAL_Delay(10);
    return result;
    int8_t user_i2c_write (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len)
    int result=0;
    uint8_t reg[]={reg_addr,*data};
    result = HAL_I2C_Master_Transmit(&hi2c1, dev_id, reg, len, HAL_MAX_DELAY);
    HAL_Delay(10);
    return result;
    void user_delay_ms (uint32_t period)
    HAL_Delay(period);
    int8_t bme680_i2c_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t lenr)
    static uint8_t cmd[30];
    cmd[0] = reg_addr ;
    HAL_I2C_Master_Transmit(&hi2c1, dev_id, cmd, 1,HAL_MAX_DELAY);
    HAL_Delay(10);
    return HAL_I2C_Master_Receive(&hi2c1, dev_id, cmd, lenr, HAL_MAX_DELAY);
    int8_t bme680_i2c_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t lenr)
    static uint8_t cmd[2];
    cmd[0] = reg_addr ;
    cmd[1] = (uint8_t )*data ;
    return HAL_I2C_Master_Transmit(&hi2c1, dev_id, cmd, lenr,HAL_MAX_DELAY);
    void init_bme (void)
    /* Select the power mode */
    | BME680_GAS_SENSOR_SEL;
    rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
    /* Set the power mode */
    int main(void)
    HAL_Init();
    SystemClock_Config();
    MX_GPIO_Init();
    MX_I2C1_Init();
    MX_USART1_UART_Init();
    RetargetInit(&huart1);
    gas_sensor.dev_id = BME680_I2C_ADDR_SECONDARY;
    gas_sensor.read = user_i2c_read;
    gas_sensor.write = user_i2c_write;
    gas_sensor.delay_ms = user_delay_ms;
    gas_sensor.amb_temp = 25;
    init_bme();
    printf("Chip_id : %x :%d\r\n",gas_sensor.chip_id,rslt);
    if(rslt!=0)
    while(1);
    uint8_t data1[1]= {140};
    uint8_t reg_addr[1]={0x2B};
    uint8_t rega[1]={0x72};
    uint8_t regs[1]={0x74};
    bme680_set_regs(reg_addr, data1 , 2, &gas_sensor);
    bme680_set_regs(rega, data1, 1, &gas_sensor);
    bme680_set_regs(regs, data1, 2, &gas_sensor);
    HAL_Delay(500);
    uint16_t meas_period;
    while (1)
    /* USER CODE END WHILE */
    user_delay_ms(meas_period); /* Delay till the measurement is ready */
    HAL_Delay(100);
    printf( "TEMPERATURE : %d\r\n", data.temperature);
    HAL_Delay(500);
    printf( "PRESSURE : %ld\r\n", data.pressure);
    HAL_Delay(500);
    printf( "HUMIDITY: %ld \r\n", data.humidity);
    HAL_Delay(1500);
    printf( "GAS RESISTANCE :%f \r\n", (data.gas_resistance /1000.0));
    //nrf_delay_ms(500);
    if (data.status & BME680_GASM_VALID_MSK){
    printf( "GAS RESISTANCE :%ld \r\n", data.gas_resistance);
    HAL_Delay(1000);
    uint32_t comp_gas = log(data.gas_resistance) + 0.04 * (log(data.gas_resistance)/data.humidity) * data.humidity;
    printf( "GAS IAQ : %ld \r\n", comp_gas);
    if (gas_sensor.power_mode == BME680_FORCED_MODE)
    RCC_OscInitTypeDef RCC_OscInitStruct = {0};
    RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
    RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
    __HAL_RCC_PWR_CLK_ENABLE();
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
    RCC_OscInitStruct.HSIState = RCC_HSI_ON;
    RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
    if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
    /** Initializes the CPU, AHB and APB buses clocks
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
    |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
    RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
    PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_I2C1;
    PeriphClkInitStruct.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
    PeriphClkInitStruct.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
    Error_Handler();
    * @brief I2C1 Initialization Function
    * @param None
    * @retval None
    /* USER CODE BEGIN I2C1_Init 0 */
    /* USER CODE END I2C1_Init 0 */
    /* USER CODE BEGIN I2C1_Init 1 */
    /* USER CODE END I2C1_Init 1 */
    hi2c1.Instance = I2C1;
    hi2c1.Init.Timing = 0x00303D5B;
    hi2c1.Init.OwnAddress1 = 0;
    hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
    hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
    hi2c1.Init.OwnAddress2 = 0;
    hi2c1.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
    hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
    hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
    if (HAL_I2C_Init(&hi2c1) != HAL_OK)
    Error_Handler();
    /** Configure Analogue filter
    if (HAL_I2CEx_ConfigAnalogFilter(&hi2c1, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
    Error_Handler();
    /** Configure Digital filter
    if (HAL_I2CEx_ConfigDigitalFilter(&hi2c1, 0) != HAL_OK)
    Error_Handler();
    /* USER CODE BEGIN USART1_Init 0 */
    /* USER CODE END USART1_Init 0 */
    /* USER CODE BEGIN USART1_Init 1 */
    /* USER CODE END USART1_Init 1 */
    huart1.Instance = USART1;
    huart1.Init.BaudRate = 115200;
    huart1.Init.WordLength = UART_WORDLENGTH_8B;
    huart1.Init.StopBits = UART_STOPBITS_1;
    huart1.Init.Parity = UART_PARITY_NONE;
    huart1.Init.Mode = UART_MODE_TX_RX;
    huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    huart1.Init.OverSampling = UART_OVERSAMPLING_16;
    huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
    huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
    if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
    * @brief GPIO Initialization Function
    * @param None
    * @retval None
    /* GPIO Ports Clock Enable */
    __HAL_RCC_GPIOB_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    /* USER CODE BEGIN 4 */
    /* USER CODE END 4 */
    * @brief This function is executed in case of error occurrence.
    * @retval None
    void Error_Handler(void)
    /* USER CODE BEGIN Error_Handler_Debug */
    /* User can add his own implementation to report the HAL error return state */
    __disable_irq();
    while (1)
    /* USER CODE END Error_Handler_Debug */
    #ifdef USE_FULL_ASSERT
    * @brief Reports the name of the source file and the source line number
    * where the assert_param error has occurred.
    * @param file: pointer to the source file name
    * @param line: assert_param error line source number
    * @retval None
    void assert_failed(uint8_t *file, uint32_t line)
    /* USER CODE BEGIN 6 */
    /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
    /* USER CODE END 6 */
    #endif /* USE_FULL_ASSERT */
    /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
    Hello ,
    In "https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/How-to-interface-STM32F769I-DISCO-to-BME...", we have provided reference code on STM32. Could you compare reference code with your code first?
