    Internal calibration for humidity, other parameters
    mayor
    I have three BME680 sensors whose readings you can see below. They are in the same location, so I would expect readings to be within specified tolerances.
    You can see that the "yellow" sensor is off, especially with regards to humidity.
    I have not seen APIs to apply humidity calibration. Can this be done within the sensor, so that IAQ readings take it into account, and not as a post-reading calculation?
    Note the gas readings are also very different.
    This isn't confidence-inspiring, but I am willing to try whatever is suggested here.
    Minhwan
    Re: Internal calibration for humidity, other parameters
    Hello mayor,
    Which API or BSEC are you using it?
    We calibrate humidity using calc_humidity fucntion.
    It should be located in bme680.c or bmx680.c.
    mayor
    Hi Minhwan,
    I had seen that function which takes into account factory "dev->calib.par_h*" parameters. There is no API or documentation (besides reverse-engineering the code in that function) to adjust those params. I'm not even sure they are writable?
    But even then, I use BSEC...
    Minhwan
    Hello Mayor,
    I'm confused. So please let me clear.
    The files I mentioned (bme68x.c and bme680.c) are used in BSEC.
    You can find in our library folder. For example bsec2 case,
    \bsec_2-0-6-1_generic_release_04302021\BSEC_2.0.6.1_Generic_Release_04302021\examples\bsec2\src\bme68x\bme68x.c
    mayor
    Interesting, I am on 1.4.8 and can't find a download on the Bosch site for V2.
    In any event, is there now documentation for the calibration registers? Are they writable?
