    Is BMA2x2 driver designed to be used in a synchronous way?
    KamWo
    there is one thing that bothers me, the whole API depends on:
    #define BMA2x2_BUS_READ_FUNC(dev_addr, reg_addr, reg_data, r_len) bus_read(dev_addr, reg_addr, reg_data, r_len)
    and it's the function which must be implemented by the user as it's specific for every MCU.
    I use I2C to read every byte in ISR and store it one at a time in a buffer. Reading data in that way does not allow me to use the BMA2x2 driver as is.
    My questions are:
    Does the BMA2x2_BUS_READ_FUNC function is meant to be synchronous(it looks so)?
    Does it have to block the whole program and wait for every byte from a bus (I2C/SPI) with busy waiting and is the whole API designed this way?
    Is there a way to use this API easily with interrupts?
    14 REPLIES 14
    Hello BSTRobin,
    your post basically exhausts the subject. Thank you.
    Hello KamWo,
    This set of driver code is for global customers, the actual project is using this set of code, has been verified to be available.
    Where can I find the project?
    Hello KamWo,
    These projects were on customer side.
    I thought that maybe there is some sample project.
    The subject is exhausted.
    Thank you BSTRobin.
