02-10-2021 12:13 PM
Hello, I'm developing a board with BMX160.
The board reads accelerometer data register and converts G to m/s without Fast Offset Compensation.
When bmx160 is in standstill, the value is (Accel: -0.06, -0.44, 10.54) m/s unit.
I think accel value is under or equal with 9.8m/s.
Is it valid?
02-10-2021 06:17 PM
Hello jinew,
When any accelerometer sensor stands on, the value should be x,y,z = 0, 0, 9.8 m/s2 (g) because it is affected by gravity only.
02-15-2021 01:03 PM
Before applying FCO, the value exceeded 9.82, but when applying FOC, the value of 9.82 came out.
When FOC is not applied, is it correct that a value over 9.82 comes out due to various noises?
or
Is it correct that 9.82m^2 comes out even before applying foc?
02-19-2021 11:17 PM
Hello Jinew,
Without FOC, BMX160 could have some offset value or not as you thought.
Using FOC function, it removes the potential risk.
Therefore, BMX160 could generate 9.82m^2 without FOC or have some offset if you don't use FOC function.
