07-28-2024 03:42 PM
Can I use the BHI160 Sensor Hub Arduino library (https://github.com/boschsensortec/BoschSensorHub) with the BHI160B? Looking at other posts in this Forum, people seem to be having issues with this. I now wonder if this is the standard case or if those were just exceptions. Will the example codes work out of the box or will modifications be necessary?
07-30-2024 02:10 PM
Hi FHansen,
Thank for your inquiry.
Yes, you can use Sensor Hub Arduino library for both BHI160B and BHI160. But you should use firmware "*_di03.*" for BHI160B, and use "*_di01.*" for BHI160.
