06-25-2020 01:45 AM
I found an article on digikey that stated "Bosch Sensortec provides the BSEC as a binary distribution for major instruction set architectures including... Renesas RL78 MCUs" but have not be able to find a library that works.
07-03-2020 02:05 AM
Thanks for the information.
I had double checked. the current BSEC lib for RL78 is not same compiler setting as yours which means i can't send that verion to you directly.
Does it possible to contact your local FAE for further step of customized BSEC lib for you?
