    Issue using BSEC2 on ESP32S3 XIAO board
    Syncrasy_RnD
    Im trying to test BME688 on a sparfun breakout board, using ESP32S3 XIAO board (a small form factor board from SeeedStudio). I was able to successfully use this sensor in BME680 mode, i.e. with no BSEC2 library. Now, im trying to run basic_config_state.ino sample using BSEC2 for coffee detection, but im getting "error code : -34" as soon as code compiled and loaded. Before this test, I was able to successfully run this sample on the Adafruit 8266 FUZZAH board with no issue.
    The only modification i added for ESP32S3 is a definition for i2c:
    int sda_pin = D4; // GPIO5 as I2C SDA
    int scl_pin = D5; // GPIO6 as I2C SCL
    void setup()
        Wire.setPins(sda_pin, scl_pin); // Set the I2C pins before begin
        Wire.begin();
    Can you help me out with this problem?
    thanks,
    0 REPLIES 0
