    Linking BSEC library to ESP-IDF for BME680
    Apurva
    I am using the BME680 with the ESP32-PoE and I want to use the BSEC library to get the IAQ. I have been stuck at the last step of linking the pre-built libalgobsec.a library. This is what my CMakeLists file in my BSEC components folder looks like:
    set(COMPONENT_SRCS "bme680.c"
    "bsec_integration.c")
    set(COMPONENT_ADD_INCLUDEDIRS "include")
    register_component()
    add_library(algobsec STATIC IMPORTED)
    set_property(TARGET algobsec PROPERTY IMPORTED_LOCATION ../lib/libalgobsec.a)
    I have not done the 3 steps for linking as stated in the Integration Guide as I do not know where to find the files to which I need to make changes. I am currently getting this error when I build the project:
    I would really appreciate any help to get the library running. Thank you!
    8 REPLIES 8
    Hello! I managed to fix the issue. I separated the BME680 files from the BSEC files. My BSEC component structure is as follows:
    • include (folder)
    1. bsec_datatypes.h
    2. bsec_integration.h
    3. bsec_interface.h
    • lib (folder)
    1. libalgobsec.h (normal)
    • bsec_integration.c
    • CMakeLists.txt
    • component.mk
    The CMakeLists.txt contains:
    CODE: SELECT ALL
    set(COMPONENT_SRCS
    set(COMPONENT_ADD_INCLUDEDIRS include)
    set(COMPONENT_REQUIRES "BME680")
    target_link_libraries(${COMPONENT_TARGET} "-L${CMAKE_CURRENT_LIST_DIR}/lib")
    target_link_libraries(${COMPONENT_TARGET} algobsec)
    The component.mk contains:
    CODE: SELECT ALL
    COMPONENT_SRCDIRS := .
    COMPONENT_ADD_INCLUDEDIRS := include
    LIBS := algobsec
    COMPONENT_ADD_LDFLAGS     := -lbt -L $(COMPONENT_PATH)/lib \
                               $(addprefix -l,$(LIBS))
    ALL_LIB_FILES := $(patsubst %,$(COMPONENT_PATH)/lib/lib%.a,$(LIBS))
    COMPONENT_ADD_LINKER_DEPS := $(ALL_LIB_FILES)
    COMPONENT_SUBMODULES += lib
    My BME680 component structure is as follows:
    • include (folder)
    1. bme680.h
    2. bme680_defs.h
    3. bme680_platforms.h
    4. bme680_types.h
    • bme680.c
    • bme680_platform.c
    • CMakeLists.txt
    • component.mk
    CODE: SELECT ALL
    set(COMPONENT_SRCS "bme680_platform.c"
                       "bme680.c")
    CODE: SELECT ALL
    handytech
    Thanks a lot for sharing your findings! 🙂
    Hi. I would like to ask you whether it would not be possible to provide function project which calculate IAQ using BME680 sensor. I am an university student, working on my bachelor final thesis and I am a little bit confused how to implement BSEC library in ESP-IDF enviroment. I couldnt even find files which was implemented here and also integration guide is only with Arduino example and not ESP-IDF. If you can help me I would be very glad. Thanks.
    I am also trying to interface BME680 sensor in ESP32-S3 using Expressif-IDE. i have downloaded the example codes bsec_1-4-9-2_generic_release & BME68x-Sensor-API-4.4.7.zip from BSEC , but i could not find the bme680_platform.c, bme680_platform.h, bme680_types.h files. Can you tell me where i can find these files. I assume that bsec_1-4-9-2_generic_release will use bme680 sensor apis.
