    Looking for a fast NO2/NOX sensor with a high accuracy
    KjellzB
    Hello
    We are currently looking for a NO2/NOx sensor for a research project. This will be attached to a multicopter drone and will measure the NO2/NOx concentration in a vertical profile in the lower atmosphere. The sensor needs to meet the following requirements:
    Mass: max. 1.5kg
    Max. dimensions: 300x80x80 mm
    Power supply: <= 24V
    Protocol: I2C, serial or CAN (has to work with Raspberry Pi or Arduino)
    Humidity range: 10-90% r.H.
    Heated: Yes (to allow measurements at higher humidities)
    Measuring range: 0-1 ppm (or higher, as long as the measuring accuracy does not suffer)
    Linearity: 4% of reading < 5 ppb
    Response time: < 180s
    Zero drift and span drift: < 6 ppb in 12h
    Does BOSCH sensors offer a sensor that meets these reuqirements?
    NO2/NOx is necessary (with the specs listed in the first post), other gases are nice to have but are not necessary. The website behinf your link is not available.
    Hi KjellzB,
    I correct previous link, you could access it now.
    BME68X couldn't support to detect NO2/NOx. The gas sensor can detect Volatile Organic Compounds (VOCs), volatile sulfur compounds (VSCs) and other gases such as carbon monoxide and hydrogen in the part per billion (ppb) range. Detailed information, you could see it from https://www.bosch-sensortec.com/products/environmental-sensors/gas-sensors/bme688/
