    Looking for a sensor recommendation
    Taoufik
    Hello all,
    Can you recommend a pressure sensor with the specs below?
    - pressure range -7psi to +7psi
    - temperature range -40C to +65C
    - very accurate
    - preferably board mount
    shellywang
    Occasional Contributor
    Re: Looking for a sensor recommendation
    Recommend you to use  BMP38x .Our pressure range is from 300 – 1100hpa, -7psi to +7psi ca transfer to -48kPa to 48kPa. Less use cases need the pressure below zero.
