    Looking for a solution so that we can measure angle between two enclosure
    kumarsagar95
    Hi
    We are looking for a solution so that we can measure angle between two enclosure. Where 1 enclosure is stationary and second is moving from 0 to 90degree respective of stationary enclosure.
    Can you suggest a solution for this application? Even after power up it can tell exact angle between these boards.
    Sagar
    FAE_CA1
    Re: Looking for a solution so that we can measure angle between two enclosure
    You may use two 3-axis accelerometers to tell the angle between two enclosures. One is installed on the stationary enclosure and the other installed on the moving enclosure. Every time when powered on the two enclosures should not be placed vertically which means that the moving enclosure should not move left and right with respect to the stationary enclosure. Instead, the moving enclosure should move up and down with respect to the stationary enclosure when they are powered on.
