    Memory Leak in bsec Library with ESP8266
    Multi123321
    Hallo,
    I'm currently facing a problem with the bsec-Library and an ESP8266.
    I started with the basic.ino script which seems to work, but after ~30min the ESP8266 crashes and reboots. Therefore I modified the script a little bit to print the free heap size. This shows that there is a memory leak and the ESP8266 crashes after it ran out of memory.
    image.pngThis is the free heap size in bytes between two crashes.
    Is this a known problem and is there a fix for this?
    I am using this version:
    Arduino IDE: 1.8.13
    bsec: 1.6.1480
    esp8266 core: 2.7.4
    #include "bsec.h"
    extern "C" {
    #include "user_interface.h"
    // Helper functions declarations
    void checkIaqSensorStatus(void);
    // Create an object of the class Bsec
    Bsec iaqSensor;
    String output;
    // Entry point for the example
    void setup(void)
      Serial.begin(115200);
      Wire.begin();
      iaqSensor.begin(BME680_I2C_ADDR_SECONDARY, Wire);
      Serial.println(output);
      checkIaqSensorStatus();
      bsec_virtual_sensor_t sensorList[2] = {
        BSEC_OUTPUT_IAQ,
        BSEC_OUTPUT_STATIC_IAQ,
      iaqSensor.updateSubscription(sensorList, 2, BSEC_SAMPLE_RATE_CONTINUOUS);
      // Print the header
      output = "Timestamp [ms], IAQ, IAQ accuracy";
    // Function that is looped forever
    void loop(void)
      unsigned long time_trigger = millis();
      if (iaqSensor.run()) { // If new data is available
        output = String(time_trigger);
        output += ", " + String(iaqSensor.iaq);
        output += ", " + String(iaqSensor.iaqAccuracy);
        uint32_t free = system_get_free_heap_size();
        Serial.print("Free RAM: ");
        Serial.println(free);
      } else {
    // Helper function definitions
      if (iaqSensor.status != BSEC_OK) {
        if (iaqSensor.status < BSEC_OK) {
          Serial.println("Error");
          for (;;) {}
        } else {
          Serial.println("Warning");
      if (iaqSensor.bme680Status != BME680_OK) {
        if (iaqSensor.bme680Status < BME680_OK) {
          for (;;) {}
        } else {
     This is the output of the ESP8266 Exception Decoder:
    Exception 29: StoreProhibited: A store referenced a page mapped with an attribute that does not permit stores
    PC: 0x4000df64
    EXCVADDR: 0x00000000
    Decoding stack results
    0x40100508: pvPortZalloc(size_t, char const*, int) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\heap.cpp line 301
    0x4021e0bc: mem_malloc at core/mem.c line 210
    0x40100154: ets_post(uint8, ETSSignal, ETSParam) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_main.cpp line 177
    0x402068d5: Bsec::setState(unsigned char*) at C:\Users\{USER}\Documents\Arduino\libraries\BSEC_Software_Library\src\bsec.cpp line 286
    0x40206ca9: Bsec::run(long long) at C:\Users\{USER}\Documents\Arduino\libraries\BSEC_Software_Library\src\bsec.cpp line 209
    0x402068d8: Bsec::setState(unsigned char*) at C:\Users\{USER}\Documents\Arduino\libraries\BSEC_Software_Library\src\bsec.cpp line 286
    0x40106b39: Twi::busywait(unsigned int) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_si2c.cpp line 237
    0x40208654: Twi::write_bit(bool) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_si2c.cpp line 280
    0x40210c4c: expf at /home/earle/src/esp-quick-toolchain/repo/newlib/newlib/libm/math/wf_exp.c line 44
    0x40210f1f: powf at /home/earle/src/esp-quick-toolchain/repo/newlib/newlib/libm/math/wf_pow.c line 36
    0x40206b01: Bsec::readProcessData(long long, bsec_bme_settings_t) at C:\Users\{USER}\Documents\Arduino\libraries\BSEC_Software_Library\src\bsec.cpp line 399
    0x40211240: sqrtf at /home/earle/src/esp-quick-toolchain/repo/newlib/newlib/libm/math/wf_sqrt.c line 36
    0x402085d6: Twi::write_stop() at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_si2c.cpp line 262
    0x4020884d: Twi::writeTo(unsigned char, unsigned char*, unsigned int, unsigned char) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_si2c.cpp line 349
    0x40208ab4: twi_writeTo(unsigned char, unsigned char*, unsigned int, unsigned char) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_si2c.cpp line 984
    0x40207050: TwoWire::endTransmission(unsigned char) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\Wire\Wire.cpp line 171
    0x40207078: TwoWire::endTransmission() at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\Wire\Wire.cpp line 180
    0x402066d1: Bsec::i2cWrite(unsigned char, unsigned char, unsigned char*, unsigned short) at C:\Users\{USER}\Documents\Arduino\libraries\BSEC_Software_Library\src\bsec.cpp line 578
    0x40201204: bme680_set_regs at C:\Users\{USER}\Documents\Arduino\libraries\BSEC_Software_Library\src\bme680\bme680.c line 355
    0x40207c94: __esp_yield() at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266/core_esp8266_features.h line 92
    0x40208c02: __delay(unsigned long) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_wiring.cpp line 54
    0x40206df0: Bsec::delay_ms(unsigned int) at C:\Users\{USER}\Documents\Arduino\libraries\BSEC_Software_Library\src\bsec.cpp line 533
    0x40206d65: Bsec::run(long long) at C:\Users\{USER}\Documents\Arduino\libraries\BSEC_Software_Library\src\bsec.cpp line 242
    0x40207110: HardwareSerial::write(unsigned char const*, unsigned int) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266/HardwareSerial.h line 164
    0x4020711c: HardwareSerial::write(unsigned char const*, unsigned int) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266/HardwareSerial.h line 165
    0x4020730d: Print::write(char const*) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266/Print.h line 62
    0x4020742d: Print::printNumber(unsigned long, unsigned char) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\Print.cpp line 268
    0x40209471: uart_write(uart_t*, char const*, size_t) at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\uart.cpp line 509
    0x4020736c: Print::println() at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\Print.cpp line 186
    0x40206599: loop() at C:\Users\{USER}\Downloads\temp\basic/basic.ino line 42
    0x40100175: esp_schedule() at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_main.cpp line 125
    0x40207dbc: loop_wrapper() at C:\Users\{USER}\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_main.cpp line 197
    Hello Multi123321,
    There was "BSEC Binary Size Information" document after you downloaded BSEC package.
