    NRF52840 with BME680
    pallyapd
    hello
    I am using nrf52840 with a segger embedded system I want to calculate IAQ using app timer which is generated interrupt every 3-second(LP mode) to call bsec_ iot_loop(), that's working for me .but when I call this loop every 5 minutes (300-sec ULP mode ) not able to get calculate IAQ .i develop get_timerstamp_us as below .please help me
    static void my_timer_start(void) {
    // Reset the second variable
    my_timer_seconds = 0;
    // Ensure the timer uses 24-bit bitmode or higher
    MY_TIMER->BITMODE = TIMER_BITMODE_BITMODE_24Bit << TIMER_BITMODE_BITMODE_Pos;
    // Set the prescaler to 4, for a timer interval of 1 us (16M / 2^4)
    MY_TIMER->PRESCALER = 4;
    // Set the CC[0] register to hit after 1 second
    MY_TIMER->CC[0] = 1000000;
    // Make sure the timer clears after reaching CC[0]
    MY_TIMER->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Msk;
    // Trigger the interrupt when reaching CC[0]
    MY_TIMER->INTENSET = TIMER_INTENSET_COMPARE0_Msk;
    // Set a low IRQ priority and enable interrupts for the timer module
    NVIC_SetPriority(MY_TIMER_IRQn, 7);
    NVIC_EnableIRQ(MY_TIMER_IRQn);
    // Clear and start the timer
    MY_TIMER->TASKS_CLEAR = 1;
    MY_TIMER->TASKS_START = 1;
    static uint32_t my_timer_get_ms(void) {
    // Store the current value of the timer in the CC[1] register, by triggering the capture task
    MY_TIMER->TASKS_CAPTURE[1] = 1;
    // Combine the state of the second variable with the current timer state, and return the result
    return (my_timer_seconds * 1000) + (MY_TIMER->CC[1] / 1000);
    * @brief Capture the system time in microseconds
    * @return system_current_time current system timestamp in microseconds
    static int64_t get_timestamp_us() {
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "in get us loop timestamp : %d\n\n",((int64_t)my_timer_get_ms() * 1000));
    return ((int64_t)my_timer_get_ms() * 1000);
    // Timer interrupt handler
    void MY_TIMER_IRQHandler(void) {
    if (MY_TIMER->EVENTS_COMPARE[0]) {
    MY_TIMER->EVENTS_COMPARE[0] = 0;
    // Increment the second variable
    my_timer_seconds++;
    1)is it compulsory to use sample rate  LP or ULP mode for calculating IAQ.
    2)my system is battery-operated so want to increase this sample rate for example every 15 minutes how to achieve this.
    7 REPLIES 7
    Re: NRF52840 with BME680
    Hello pallyapd,
    What is BSEC version you would like to use?
    pallyapd
    I used bsec_1-4-8-0_generic_release
    Hello pallyapd,
    You could refer attachment code used the same BSEC version with you.
    pallyapd
    thanks for responding to me. in the attached file they create a separate task for BME680 .is any other way to calculate IAQ.? what about the sampling rate ...?is it must use LP or ULP my system is battery-operated so want to custom sample rate how to overcome this problem. In my  setup, IAQ works only LP or ULP .
