    NRF52840 with BME680
    pallyapd
    hello
    I am using nrf52840 with a segger embedded system I want to calculate IAQ using app timer which is generated interrupt every 3-second(LP mode) to call bsec_ iot_loop(), that's working for me .but when I call this loop every 5 minutes (300-sec ULP mode ) not able to get calculate IAQ .i develop get_timerstamp_us as below .please help me
    static void my_timer_start(void) {
    // Reset the second variable
    my_timer_seconds = 0;
    // Ensure the timer uses 24-bit bitmode or higher
    MY_TIMER->BITMODE = TIMER_BITMODE_BITMODE_24Bit << TIMER_BITMODE_BITMODE_Pos;
    // Set the prescaler to 4, for a timer interval of 1 us (16M / 2^4)
    MY_TIMER->PRESCALER = 4;
    // Set the CC[0] register to hit after 1 second
    MY_TIMER->CC[0] = 1000000;
    // Make sure the timer clears after reaching CC[0]
    MY_TIMER->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Msk;
    // Trigger the interrupt when reaching CC[0]
    MY_TIMER->INTENSET = TIMER_INTENSET_COMPARE0_Msk;
    // Set a low IRQ priority and enable interrupts for the timer module
    NVIC_SetPriority(MY_TIMER_IRQn, 7);
    NVIC_EnableIRQ(MY_TIMER_IRQn);
    // Clear and start the timer
    MY_TIMER->TASKS_CLEAR = 1;
    MY_TIMER->TASKS_START = 1;
    static uint32_t my_timer_get_ms(void) {
    // Store the current value of the timer in the CC[1] register, by triggering the capture task
    MY_TIMER->TASKS_CAPTURE[1] = 1;
    // Combine the state of the second variable with the current timer state, and return the result
    return (my_timer_seconds * 1000) + (MY_TIMER->CC[1] / 1000);
    * @brief Capture the system time in microseconds
    * @return system_current_time current system timestamp in microseconds
    static int64_t get_timestamp_us() {
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "in get us loop timestamp : %d\n\n",((int64_t)my_timer_get_ms() * 1000));
    return ((int64_t)my_timer_get_ms() * 1000);
    // Timer interrupt handler
    void MY_TIMER_IRQHandler(void) {
    if (MY_TIMER->EVENTS_COMPARE[0]) {
    MY_TIMER->EVENTS_COMPARE[0] = 0;
    // Increment the second variable
    my_timer_seconds++;
    1)is it compulsory to use sample rate  LP or ULP mode for calculating IAQ.
    2)my system is battery-operated so want to increase this sample rate for example every 15 minutes how to achieve this.
    7 REPLIES 7
    Hello pallyapd,
    You could see IAQ was output from BSEC.
    void output_ready(int64_t timestamp, float iaq, uint8_t iaq_accuracy, float temperature, float humidity,
    float pressure, float raw_temperature, float raw_humidity, float gas, bsec_library_return_t bsec_status,
    float static_iaq, float co2_equivalent, float breath_voc_equivalent)
    PDEBUG("timestamp=%lld, iaq=%f, iaq_accuracy=%d, temperature=%f, humity=%f, pressure=%f, \
    raw_temperature=%f, raw_humity=%f, gas=%f, bsec_status=%d, static_iaq=%f, co2_equivalent=%f, \
    breath_voc_equivalent=%f\r\n", timestamp, iaq, iaq_accuracy, temperature, humidity, pressure, \
    raw_temperature, raw_humidity, gas, bsec_status, static_iaq, co2_equivalent, breath_voc_equivalent);
    By default, example code used BSEC_SAMPLE_RATE_LP sample rate. YOu could select sample rate from BSEC integration guide.
    pallyapd
    in bsec only 2 configurations are available. I create a timer which is called bsec_loop every 3 seconds (lp mode) it works fine .but whenever I configure ULP mode 300 seconds IAQ is not calculated.IAQ_accurancy remains zero.
    Hello pallyapd,
    For ULP mode software, you could refer attachment source code.
