08-19-2021 06:46 PM
Need Technical Support on - BNO055 - Difference between silk print A6 and A9
08-23-2021 04:06 AM
The second row marking was internally used.
—— I know this is for your internal use, this is why I'm contacting with you to get the difference between A6 & A9.
If there is NO any special meaning, I assume A6 & A9 should have same function from the datasheet.
So, please confirm the difference between A6 & A9;
If what I ordered are fake chips, Can Bosch support me on analysising the details? Or how should we punish the sellers?
I believe Bosch should have a immediate punishment mechanism to the sellers.
We should use legal proceedings if necessary. In this case, we need support from Bosch as well.
So please don't keep silent. since this is a big deal for us.
08-23-2021 08:14 AM
Hello Sugary,
We are very sorry, but unfortunately we cannot support you in refunding the payment and have to refer you to the seller for this. We hope that this issue will be resolved as soon as possible.
08-23-2021 01:09 PM
So you are working on helpping us to solve the problem? Or you can't tell me the difference between A6 & A9?
I want to confirm with you, are the 501PCs of BNO055 chips with A6 silk print are fake chips?
Can you help me on this problem?
08-23-2021 01:12 PM
And you can do nothing support activities ? even if your customer feedback to you that your client may order fake BNO055 Chip.
08-23-2021 01:14 PM
OR you can't tell if BNO055 chips with A6 silk print is fake or not?
