03-01-2019 05:55 PM
I am trying to use a BHI160 shuttle board in conjuction with a APP 2.0 board connected through I2C
I used Desktop Development software to confirm the sensor functions, but I haven't found any good information on how to upload the Github drivers.
What tools or software do I need to start the process of programming this package?
03-04-2019 08:50 AM
Hi easeas,
We have launched a new software tool called COINES.
Accessing the Application Board 2.0 using C and SensorAPI
COINES ("COmmunication with INertial and Environmental Sensors") provides a low-level interface to Bosch Sensortec’s Application Board APP2.0. The user can access Bosch Sensortec’s MEMS sensors through a C interface. COINES can be used with the SensorAPI of the sensor. The SensorAPI is available at https://github.com/BoschSensortec . Source code of sample applications and SensorAPI are provided with the COINES library as a package. The user can modify, compile and run the sample applications.
COINES can be used to see how to use the SensorAPI in an embedded environment and allows convenient data logging.
Intended audience
This software package is intended for experienced embedded software developers with good knowledge of the programming language C and the appropriate build tools.
https://www.bosch-sensortec.com/bst/support_tools/downloads/overview_downloads
