    Nicla Sense ME calibrating BME 688 readings
    riyapatel4400
    Hello!
    I'm currently reading in the sensor data in standalone mode using the following code:
    #include "Nicla_System.h"
    #include <ArduinoBLE.h>
    #include "Arduino.h"
    #include "Arduino_BHY2.h"
    Sensor temp(SENSOR_ID_TEMP);
    Sensor humid(SENSOR_ID_HUM);
    Sensor baro(SENSOR_ID_BARO);
    void setup()
    Serial.begin(115200);
    while(!Serial);
    BHY2.begin();
    temp.begin();
    humid.begin();
    baro.begin();
    void loop()
    static auto printTime = millis();
    // Update function should be continuously polled
    BHY2.update();
    if (millis() - printTime >= 1000) {
    Serial.println(String("Temperature: ") + String(temp.value(),3) + String(" Pressure: ") + String(baro.value(),3) + String(" Humidity: ") + String(humid.value(),3));
    While we are getting readings in COM7, they don't seem to be accurate. Here's a sample output:
    18:07:14.424 -> Temperature: 27.010 Pressure: 1004.032 Humidity: 12.000
    18:07:15.405 -> Temperature: 27.020 Pressure: 1004.024 Humidity: 12.000
    The temperature in the room is measured to be 23 degrees celsius and the humidity is most definitely not 12%. Does anyone know how to calibrate teh sensor or add an offset?
    Thanks!
    Hello riyapatel4400,
    When you approach the sensor with a heat source, does the temperature change?
