    No response from board in Development Desktop with Application Board 3.0 and BHI260AP
    Jan_Frey
    I would like to carry out measurements with the Application Board 3.0 and the BHI260AP.
    For this I have installed Arc Gnu Toolchain, BHI260AP SDK and Development Desktop according to the tutorial (https://www.youtube.com/watch?v=3WyLEd2k7Kw) and the setup guide (https://www.bosch-sensortec.com/media/boschsensortec/downloads/application_notes_1/bst-bhi260ab-an00...).
    I tested it with Development Desktop 2 and 2.1. Both times I got the error "No response from the board. Please select correct port.", although I have selected the correct port (see illustration). Of course I have also tested different cables and ports.
    As you can see in the picture, the board is not recognized as a BST board as in the tutorial but is listed under the COM ports. I suspect that the driver is the reason why the board is not recognized by Development Desktop. Even running the "DriverInstaller_BSTBoard.exe" and installing the driver does not change anything.
    I have now tested the whole thing several times on different computers and always have the same problem.
    I am grateful for any help.
    Hi Jan_Frey,
    We suggest you check the following two points and try again.
    1.Install latest Development desktop software & driver.
    https://www.bosch-sensortec.com/software-tools/tools/development-desktop-software
    2.Upgrade "C:\COINES\v2.8.8\firmware\app3.0\DevelopmentDesktop_2.0_Firmware_v1.9.bin" on your application board 3.0.
    Hi BSTRobin,
    thanks for your help, but the problem was apparently the hardware. I tested it with a new application board and it worked.
    Good news, Jan_Frey.
