Hello BSTRobin
Please find attached .c and .h file along with the configuration file that we are using for getting GAS_ESTIMATE_X data.
bsec.c file is created using the arduino example present in bsec library downloaded from BOSCH website.
Your reply at the earliest will be very helpful.
Vishvaraj
Hello Robin,
Any updates on our query.
It will be really helpful to us as we are stuck and unable to find any solution
hello,
any updates??
Hello jadeja14890,
Sorry for delay reply.
You migrated Arduino project to nordic platform. Could we know the following two
1.What code do you call the API(BSEC_2.0.1.0_Internel_Release\API\bme680.c)?
2.Before you call bme680_init() in your code, what is the initialization code for struct bme680_dev?
struct bme680_dev {
/*! Chip Id */
uint8_t chip_id;
/*! Device Id */
uint8_t dev_id;
/*! Unique id */
uint32_t unique_id;
/*! SPI/I2C interface */
enum bme680_intf intf;
/*! Memory page used */
uint8_t mem_page;
/*! Ambient temperature in Degree C*/
int8_t amb_temp;
/*! Sensor calibration data */
struct bme680_calib_data calib;
/*! Read function pointer */
bme680_com_fptr_t read;
/*! Write function pointer */
bme680_com_fptr_t write;
/*! Delay function pointer */
bme680_delay_fptr_t delay_ms;
/*! Communication function result */
int8_t com_rslt;
/*! Store the info messages */
uint8_t info_msg;
Hi BSTROBIN,
Please Find Below Answer
[Ans] BSEC api callerd from Main.c in While(1) loop please see atached snapshot Main_c.png
2. Before you call bme680_init() in your code, what is the initialization code for struct bme680_dev?
Please find attached code snippet for same (Main_C.png,bme688_get_dev_structure.png, and BME688_Init.png).
