Hello All
Goof Day!!
We are integrating BSEC library with BME688 sensor on NRF SDK ,
We succesfully able to get compensated Temprature , Humidity,Pressure value from BSEC
But we are facing issue to get Gas Estimate X out from BSEC,it always show zero value even after 45 minute of test run.
And also IAQ value always show 25 and "Run in status" flag always show 0 from BSEC output.
Please suggest possible solustion of issue.
Please find detail log in Attachedment
Let me know if more information require.
Hello jadeja14890,
Could we know more detailed software information? Like software version, which example code you use...
Hello BSTRobin,
We are using BSEC version 2.0.6.1 and we refer arduino example and bsec.cpp that comes under bsec library.
let us know if more information require.
Hello jadeja14890,
If it is ok, could you provide you arduino code, we would like to check it.
Hello BSTRobin
Can you share your email ID , so we will share code and config file over mail ,as per company policy can not share propietry code over public forum.
Thank you
