    Not able to get the BME688 up and running
    Biswajeet
    I am not able to get the BME688 up and running and facing issues and need your help.
    Here are the list of things I have done so far following the "BST-BME688-Integration-Guide-AN008-06.pdf" document.
    1. Took following files from "BSEC_2.0.6.1_Generic_Release_04302021" repo : bme68x.c, bme68x.h, bme68x_defs.h, bsec_datatypes.h, bsec_interface.h, bsec_serialized_configurations_selectivity.c, bsec_serialized_configurations_selectivity.h
    2. As our source code is written in C and in the above repo has "bsec.cpp" file present so I had to convert this file from .cpp to .c. (Attached)
    3. Execution sequence :
      1. "bsec_init()" is successfull and able to read the BSEC version information.
      2. "bsec_set_configuration" returns -34 (BSEC_E_CONFIG_VERSIONMISMATCH) insted of 0(BSEC_OK).
      3. "bsec_update_subscription" returns 0(BSEC_OK).
      4. "bme68x_init" returns 0(BSEC_OK).
      5. In a infinite loop, executing "read_sensor_and_process_data" or "Bsec::run"(in bsec.cpp).
        1. Inside "set_bme68x_parallel_mode" is called and "bme68x_set_heatr_conf" functions returns -2 (BSEC_E_DOSTEPS_VALUELIMITS) after which it exits the function and runs in a loop.
    Can you please let me know where is the issue ?
    I have attached the converted c file and logs for your reference.
    Note: The library file was shared here : https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BME688-library-linking-fails-in-STM32MP1...
    14 REPLIES 14
    Shared my email via private message.
    With Best Wishes,
    Subba Rao K
    Official C code software will be released on the end of Jan 2023.
    We had released the software. You could download BSEC2.4.0.0 from https://www.bosch-sensortec.com/software-tools/software/bme688-software, which support C language code.
    With the link shared, I am getting an 404 Error. Had to edit the link as below https://www.bosch-sensortec.com/software-tools/software/bme688-software/ and then look for "Download BSEC version 2.4.0.0" to use.
    Thank for you update the download link, skodavalla.
