Dear All,
I am working with bme 680 environmental sensor interfacing with nRF52840-DK. I got Temperature, pressure and humidity data. But i am not getting Gas resistance values. i have attched my code also. I will be very happy if you help in this.
Thank you all.
Hello VinayakMH,
I think you optimize our bsec library example.
Could you use our function?
Since there is some return value in our function, we can check why it doens't work.
If you follow our example code and there is no return value, could you upload your source code one more time?
Thank you Minhwan for your reply.
This is my source code.
#include <stdio.h>
#include "boards.h"
#include "app_util_platform.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_log_default_backends.h"
#include "bme680.h"
#include "bme680_defs.h"
struct bme680_dev gas_sensor;
int8_t rslt = BME680_OK;
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
int8_t user_i2c_read (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len)
ret_code_t err;
uint8_t var[30]={0};
int size=0, result = 0, j=0;
uint8_t reg[1]={reg_addr};
nrf_drv_twi_tx(&m_twi, dev_id, reg, 1,false);
err = nrf_drv_twi_rx(&m_twi, dev_id, var, len);
if(err==0)
size=1;
for(int i = 0 ;i<30;i++)
if(var[i]!=0) size=i+1;
else
size=0;
if(size ==15)
size=len;
if(len<=size)
for (int i=0;i<len;i++)
data[i]=var[i];
else
result=5;
return result;
int8_t user_i2c_write (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len)
int result=0;
uint8_t reg[]={reg_addr,*data};
nrf_drv_twi_tx(&m_twi, dev_id, reg, len+1, false);
for(int i = 0;i<len;i++)
return result;
void user_delay_ms (uint32_t period)
nrf_delay_ms(period);
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_config = {
.scl = 27,
.sda = 26,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
APP_ERROR_CHECK(err_code);
nrf_drv_twi_enable(&m_twi);
void init_bme (void)
gas_sensor.gas_sett.heatr_temp = 300; /* degree Celsius */
gas_sensor.gas_sett.heatr_dur = 100; /* milliseconds */
/* Select the power mode */
set_required_settings = BME680_OST_SEL | BME680_OSP_SEL | BME680_OSH_SEL | BME680_FILTER_SEL| BME680_GAS_SENSOR_SEL;
rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
/* Set the power mode */
int main(void)
APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
NRF_LOG_DEFAULT_BACKENDS_INIT();
NRF_LOG_INFO("TWI scanner started.");
NRF_LOG_FLUSH();
twi_init();
gas_sensor.dev_id = BME680_I2C_ADDR_SECONDARY;
gas_sensor.read = user_i2c_read;
gas_sensor.write = user_i2c_write;
gas_sensor.delay_ms = user_delay_ms;
gas_sensor.amb_temp = 25;
init_bme();
NRF_LOG_INFO("chip_id : %d :",gas_sensor.chip_id);
NRF_LOG_FLUSH();
NRF_LOG_INFO("Rslt : %d",rslt);
NRF_LOG_FLUSH();
if(rslt!=0)
while(1);
uint8_t data[1]={140};
uint8_t regt[1]={0x74};
uint8_t regh[1]={0x72};
uint8_t regs[1]={0x71};
uint8_t addr = 0xE0;
uint8_t val = 0xB6;
bme680_set_regs(&addr, &val, 1, &gas_sensor);
bme680_set_regs(regt, data, 1, &gas_sensor);
bme680_set_regs(regh, data, 1, &gas_sensor);
bme680_set_regs(regs, data, 1, &gas_sensor);
//NRF_LOG_INFO("Register1 0x74 : %d",dat[0]);
nrf_delay_ms(500);
//NRF_LOG_INFO("Register2 0x72 : %d",dat[0]);
nrf_delay_ms(500);
NRF_LOG_FLUSH();
while (1)
uint16_t meas_period;
char temperature[20];
char pressure[20];
char humidity[20];
while(1)
nrf_delay_ms(meas_period);
//NRF_LOG_INFO("Read Result: %d",rslt);
NRF_LOG_FLUSH();
//NRF_LOG_INFO("%d",data.temperature);
nrf_delay_ms(2000);
NRF_LOG_FLUSH();
NRF_LOG_ERROR( "TEMPERATURE : " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.temperature /100.0));
NRF_LOG_FLUSH();
nrf_delay_ms(2000);
NRF_LOG_ERROR( "PRESSURE : " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.pressure/1000.0));
NRF_LOG_FLUSH();
nrf_delay_ms(2000);
NRF_LOG_ERROR( "HUMIDITY: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.humidity /1000.0));
NRF_LOG_FLUSH();
nrf_delay_ms(2000);
//NRF_LOG_ERROR( "GAS: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.gas_resistance /1000.0));
//NRF_LOG_FLUSH();
//nrf_delay_ms(500);
if (data.status & BME680_GASM_VALID_MSK)
NRF_LOG_ERROR( "GAS RESISTANCE : " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.gas_resistance /1000.0));
NRF_LOG_FLUSH();
nrf_delay_ms(500);
Hello VinayakMH,
You don't follow our producesure 100%.
Please check our example and follow it. And also please get return value, and we can find where you get some error and why.
Hi Mr.Minhwan.
I got the all TPHG (Temperature , Pressure , Humudity and Gas) values. Kindly tell me the BSEC integration steps.
I have 6 questions on this topic, as I mentioned below.
1) As I have used your BOSCH BME680 drivers and wrote my own main.c in nRF52840-DK (Development Kit) and getting precise outputs of TPHG, so can I integrate BSEC directly to my project?
2) If yes how can I integrate BSEC to my project? If no, kindly send me the steps to do it.
3) So, after integrating BSEC to my project will i get the precised converted values directly?or
4) Should i modify / develop my main.c code for BSEC? or
5) According to my main.c should i modify / develop the BSEC?
6) Are there any steps to achieve it? If any, kindly give me the hints or links to achive it.
