    Probably a bug in BME688/BSEC 2.0 with 4 classes
    Danj
    We tried to use all 4 classes in the BME AI-Studio:
    Class A: Air
    Class B: Coffee
    Class C: Tea
    Class D : Flower
    Then in our application with BSEC Library we got for Air:
    BSEC_OUTPUT_GAS_ESTIMATE_1=0.00
    BSEC_OUTPUT_GAS_ESTIMATE_2=0.99
    BSEC_OUTPUT_GAS_ESTIMATE_3=0.00
    BSEC_OUTPUT_GAS_ESTIMATE_4=0.00
    for Coffee the same:
    It looks like BSEC_OUTPUT_GAS_ESTIMATE_1 doesn't change at all.
    If we remove classes C and D from the algorithm, we get for Air:
    BSEC_OUTPUT_GAS_ESTIMATE_1=0.99
    BSEC_OUTPUT_GAS_ESTIMATE_2=0.00
    and for Coffee:
    this is correct.
    BME AI Studio: 1.6.0
    BME68x: 4.4.6
    BSEC: 2.0.6.1
    MightyNate
    I'm afraid I can't help you with your question, but I wonder how you managed to retrieve the values for BSEC_OUTPUT_GAS_ESTIMATE_X.
    Whatever sample rate I use to subscribe the BSEC_OUTPUT_GAS_ESTIMATE_X the bsec_update_subscription function returns an error.
    That's why I wonder if I really need to subscribe them explicitly or whether it is enough to pass the config that I received from AI Studio to the bsec_set_configuration function?
    If I get the BSEC_OUTPUT_GAS_ESTIMATE_X to work I will try to replicate the bug for comparison.
    1. Sample rate must be BSEC_SAMPLE_RATE_HIGH_PERFORMANCE
    2. Need to subscribe to all BSEC_OUTPUT_GAS_ESTIMATE_X (BSEC_OUTPUT_GAS_ESTIMATE_1,BSEC_OUTPUT_GAS_ESTIMATE_2,BSEC_OUTPUT_GAS_ESTIMATE_3,BSEC_OUTPUT_GAS_ESTIMATE_4). Even if you only use 2 classes.
    You can see the logic of use in the example for BCEC 2.0.
    Hello Danj,
    Has you correctly labeled the gas? Maybe you can make the data collection time longer for each different kind of gas and have a try.
    You shall make sure that the air is the fresh air without other smell.
    Coffee for training and coffee for field test shall be the same concentration.
    Hello Danj,
    Could you give further feedback?
