    Problem Reading data via SPI - BME680 STM32.
    giwed
    I am implementing the BME680 on a project. I am trying it with the STM32F407 dev board using SPI1.
    I can not read any data, could you help me? I really don't know what am i missing.
    - Drivers: https://github.com/BoschSensortec/BME680_driver
    Code Snippet:
     void main(){
    bme680_start(&gas_sensor);
    uint16_t meas_period = 180;
    HAL_Delay(meas_period);
    while(1){
    bme680_get_sensor_data(&data, &gas_sensor);
    t680 = (uint32_t) data.temperature / 100.0;
    h680 = (uint32_t) data.humidity / 1000.0;
    p680 = (uint32_t) data.pressure / 1000.0;
    // Trigger the next measurement if you would like to read data out continuously
    if(gas_sensor.power_mode == BME680_FORCED_MODE) bme680_set_sensor_mode(&gas_sensor);
    HAL_GPIO_TogglePin(GPIOD,GPIO_PIN_14);//toggle led
    /* ----- USER FUNCTIONS ------ */
    void bme680_start(struct bme680_dev * gas_sensor){
    gas_sensor->dev_id = 0;
    gas_sensor->intf = BME680_SPI_INTF;
    gas_sensor->read = user_spi_read;
    gas_sensor->write = user_spi_write;
    gas_sensor->delay_ms = user_delay_ms;
    gas_sensor->amb_temp = 20;
    int8_t rslt = BME680_OK;
    rslt = bme680_init(gas_sensor);
    gas_sensor->tph_sett.os_hum = BME680_OS_2X;
    gas_sensor->tph_sett.os_pres = BME680_OS_4X;
    gas_sensor->tph_sett.os_temp = BME680_OS_8X;
    gas_sensor->tph_sett.filter = BME680_FILTER_SIZE_3;
    gas_sensor->gas_sett.run_gas = BME680_ENABLE_GAS_MEAS;
    gas_sensor->gas_sett.heatr_temp = 320; /* degree Celsius */
    gas_sensor->gas_sett.heatr_dur = 150; /* milliseconds */
    /* Select the power mode */
    gas_sensor->power_mode = BME680_FORCED_MODE;
    set_required_settings = BME680_OST_SEL | BME680_OSP_SEL | BME680_OSH_SEL | BME680_GAS_SENSOR_SEL | BME680_FILTER_SEL;
    rslt = bme680_set_sensor_settings(set_required_settings,gas_sensor);
    /* Set the power mode */
    rslt = bme680_set_sensor_mode(gas_sensor);
    void user_delay_ms(uint32_t period)
    HAL_Delay(period);
    int8_t user_spi_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    int8_t rslt = 0;
    dev_id = 0;
    HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,GPIO_PIN_RESET); //CS low
    HAL_SPI_Transmit(&hspi1, &reg_addr, 1, 100);
    HAL_SPI_Receive(&hspi1, reg_data, len, 100);
    HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,GPIO_PIN_SET); //cs high
    return rslt;
    int8_t user_spi_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    int8_t rslt = 0;
    dev_id = 0;
    HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,GPIO_PIN_RESET); //cs low
    HAL_SPI_Transmit(&hspi1, &reg_addr, 1, 150);
    HAL_SPI_Transmit(&hspi1, reg_data, len, 150);
    return rslt;
    This image show the results:
    meas_period = 183ms, t680 = 42949672, p680 = 22
    Hello giwed,
    For your SPI read and write functio, they are no correct. You could refer the following reference code on STM32 and test it again.
    uint8_t GTXBuffer[512], GRXBuffer[512];
    * Function Name : SPI_Read
    * Description : Write data into slave device.
    * Input : I2C1 or I2C2, slave_address7, subaddress, Write Number
    * Output : None
    * Return : number of bytes transmitted
    int8_t SensorAPI_SPIx_Read(uint8_t slave_address7, uint8_t subaddress, uint8_t *pBuffer, uint16_t ReadNumbr)
    slave_address7 = slave_address7;
    GTXBuffer[0] = subaddress | 0x80;
    HAL_GPIO_WritePin(SPI_CS_GPIO_Port, SPI_CS_Pin, GPIO_PIN_RESET); // NSS low
    HAL_SPI_TransmitReceive(&SPI_HANDLE, GTXBuffer, GRXBuffer, ReadNumbr+1, BUS_TIMEOUT); // timeout 1000msec;
    while(SPI_HANDLE.State == HAL_SPI_STATE_BUSY); // wait for xmission complete
    HAL_GPIO_WritePin(SPI_CS_GPIO_Port, SPI_CS_Pin, GPIO_PIN_SET); // NSS high
    memcpy(pBuffer, GRXBuffer+1, ReadNumbr);
    return 0;
    int8_t SensorAPI_SPIx_Write(uint8_t slave_address7, uint8_t subaddress, uint8_t *pBuffer, uint16_t WriteNumbr)
    GTXBuffer[0] = subaddress & 0x7F;
    memcpy(&GTXBuffer[1], pBuffer, WriteNumbr);
    //HAL_SPI_TransmitReceive(&hspi2, pTxData, pRxData, WriteNumbr+1, BUS_TIMEOUT); // send register address + write data
    HAL_SPI_Transmit(&SPI_HANDLE, GTXBuffer, WriteNumbr+1, BUS_TIMEOUT); // send register address + write data
    return 0;
    Thanks it works.
    Anyway I am receving wrong data:
    The temperature doesn't make any sense (77 in decimal). Humidity = 0. Im missing something..
    Hello giwed,
    Which example code you used?
    There was reference code in github. You could refer it.
    https://github.com/BoschSensortec/BME68x-Sensor-API/blob/master/examples/forced_mode/forced_mode.c
    Spoiler
    Hi
    Can you share me SPI code ,just to refer what changes you make with code .
